Re: Better Ignition system.
[Re: Crabra]
#2171462
10/10/16 02:02 PM
10/10/16 02:02 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I switched away from the stock type ECU to the MSD Street Fire box back in 2012. This box is a little bit larger than the ECU and it has a rev limiter. At that time, it was stock on Oreilly's shelf.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Crabra]
#2171493
10/10/16 03:01 PM
10/10/16 03:01 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
I prefer the MSD over the orange ECU. It's been my experience that the orange boxes pop, sometimes just sitting over a period of time. They are real sensitive to grounding issues. When I run the orange box I always run a separate ground wire.
Abe Lincoln
[Re: Crabra]
#2171512
10/10/16 03:31 PM
10/10/16 03:31 PM
RapidRobert
Now it seems I have a pick up promblem. More details, whats going on?
[Re: dart4forte]
#2171513
10/10/16 03:33 PM
10/10/16 03:33 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I'm also running the MSD Street-Fire box but using it with an MSD distributor and coil...No ballast resistor...
...FAFO...
[Re: Jim_Lusk]
#2176641
10/17/16 02:41 AM
10/17/16 02:41 AM
RapidRobert
I vote for the HEI. you can mount it under the dist on an alum plate (use some radio shack heat sink paste) & someone makes a tailor made plate for this but it is pricey & it is easy to make yourself. An OE black 4 terminal one out of a '75 or later chebby is a good bet or an aftermarket one. best is to use a full 12V E coil with it and B terminal goes to ign1/ign2 (blue and brown wires connected together at ballast or earlier) and C terminal goes to coil negative and W and G go to the dist pickup. orange goes to W and purple goes to G. EDIT www.designed2drive.com for the adapter plate, $25 to your door. make it yourself.
