Re: D100 Charging Woes
[Re: Sxrxrnr]
#2173158
10/12/16 09:35 PM
10/12/16 09:35 PM
RapidRobert
Or do you find battery is dead after vehicle has been parked for some period of time? Good point. wait till it gets good and dark & pull a batt cable & touch it back to the post & ANY spark is too much & as said means there is an unwanted key off draw. (unless you have a windup clock or a lighted digital display on a stereo etc & those are not near enough to run it down unless for a long period of idle time) which I don't think we are dealing with here.
[Re: elmor353]
#2174865
10/14/16 10:23 PM
10/14/16 10:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A working alternator needs two things to generate electricity.
On a dual field terminal alternator you need battery voltage on one connection and ground on the other. The VR will vary the ground to control the battery voltage. The VR has two inputs, one is battery voltage, and it should be within a tenth of a volt of what you read at the battery, the other is a ground through the mounting bolts. The second wire at the VR goes to the alternator field terminal and it the control mentioned above. The large stud on the alternator is the output.
So with the key on, engine off, you had better read battery voltage at the VR and the alternator field terminal, usually this is a blue wire. They had best read within .1V of what you read at the battery positive, using the same ground, I usually use the battery negative post. If you jumper on field terminal to battery + and the other to battery - (stock wiring disconnected) the alternator will generate power out. As a very short term test this is ok. If either of the wires from the VR to the alternator doesn't have the correct signal on it the alternator will not work.
On a single field terminal alternator, the ground is handled thru the brush mount and the VR controls the battery voltage to the remaining field terminal, usually a blue wire. On the old mechanical regulator setup it simply switches the battery voltage to the field on or off. Electronic versions are a bit smoother than that. Disconnect the wire from the one field connection, jumper the terminal to battery + for the short term test.
[Re: elmor353]
#2175798
10/16/16 08:41 AM
10/16/16 08:41 AM
Posts: 5,991 ohio
ruderunner
ohio
Super, good description of testing the two styles but possibly confusing to the op.
Op, your truck originally had a dual field alternator, follow the first part of Supers post.
Angry white pureblood male
[Re: elmor353]
#2175812
10/16/16 09:17 AM
10/16/16 09:17 AM
Supercuda
About to go away
About to go away
up yours
I might have to make a video, but I only have the single field terminal, mechanical setup. Be a good start, just gotta stick the engine back into the Cuda.
[Re: elmor353]
#2176421
10/16/16 09:59 PM
10/16/16 09:59 PM
Posts: 5,991 ohio
ruderunner
ohio
14.5 isn't too high especially with a run down battery. I'd run it for a bit to get a charge on the battery and recheck.
Most Mopar are around 13.5-14 with a charged battery.
[Re: elmor353]
#2176486
10/16/16 10:57 PM
10/16/16 10:57 PM
Supercuda
About to go away
About to go away
up yours
12.8V at the battery, engine off is pretty much a fully charged battery. So looks like you are good to go.
[Re: elmor353]
#2176917
10/17/16 02:38 PM
10/17/16 02:38 PM
Posts: 5,991 ohio
ruderunner
ohio
I'd monitor it for a couple days. He may be on the verge of overcharged.
BTW, 12.8 volts at the battery sounds like just a surface charge. Turn n the headlights for a minute, turn them off and recheck battery voltage.
