DANA 60 Question #217014
02/07/09 08:23 PM
02/07/09 08:23 PM
Sth.IL
dare_dude Offline OP
Sth.IL
Reworking my old 60 knocked out old rear pinion race. It was snug but came out. New one seemed to just drop in offly easy. I have heard this is not good?
Re: DANA 60 Question [Re: dare_dude] #217015
02/07/09 08:53 PM
02/07/09 08:53 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
3 choices,
Use green sleeve retainer Locktite.
or Use a rosebud torch and shrink the bore which will change the gear setup pattern a little
or strip the housing and send it to a machine shop and have a sleeve installed.
I'd do and have many times done the second choice.
Re: DANA 60 Question [Re: RussW] #217016
02/07/09 09:22 PM
02/07/09 09:22 PM
Sth.IL
Sth.IL
So is housing JUNK!
Re: DANA 60 Question [Re: dare_dude] #217017
02/07/09 09:31 PM
02/07/09 09:31 PM
RussW Offline
super gas
RussW  Offline
super gas
So is housing JUNK!
No , easy fix.
Re: DANA 60 Question [Re: RussW] #217018
02/08/09 12:14 AM
02/08/09 12:14 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Does the old race fit snug to go back in?
Does the old race have the same number as the new one?
It could be as simple as a parts error.
Re: DANA 60 Question [Re: dave571] #217019
02/08/09 01:52 AM
02/08/09 01:52 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I wouldn't rule out that the bearing was manufactured on the low side of the specs. You might get another bearing race from a different source just to prevent another bearing from the same lot or production run. Beep
