Re: Anybody pushing a stock 340 block hard?
[Re: Ian]
#2168818
10/06/16 05:25 AM
10/06/16 05:25 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
[/quote] i have not raced here yet mate ,but have crewed with andrews just a 6 running some great numbers and the track is great here and the whole community gets behind it ,thats the difference mate very family frendly [/quote] Bewdy , may get there 1 day . That justa6 is out of my league
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: dogdays]
#2169336
10/06/16 11:08 PM
10/06/16 11:08 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
The Venetian blinds in the rear window were a little-old-man thing back in the real early '70s in my part of the USA. If a young person bought a car with them in, they got removed the first hour. Definitely uncool back then.
Same as caps with earflaps that tie under the chin. Back then, no way would a kid be caught wearing something like that. Now they're all over the states,, made in Peru or places like that.
The longer I live, the stranger it gets.....
R. I'll bite..... where are you going with that?
[Re: ozymaxwedge]
#2169359
10/06/16 11:52 PM
10/06/16 11:52 PM
Posts: 4,457 Washington
madscientist
Washington
not to change the subject , but Ian what's with the back window i have seen a lot of au vids and wondered whats with the window blinds it a metal blind ,done for early cars in the 60,s it keeps the sun of the top of your back seat so it does not crack open .and it hides the cage and gives it a little retro/sleeper look and makes the car look cool lol Got the number of carbs right, just too many doors! Hopefully it has 3 pedals.
[Re: SpareParts]
#2169369
10/07/16 12:05 AM
10/07/16 12:05 AM
Posts: 171 Columbus, OH
redruM
Columbus, OH
Going to the Turkey Bash? I doubt it, I like Mexico stuff
[Re: redruM]
#2169745
10/07/16 05:14 PM
10/07/16 05:14 PM
dogdays
[Re: pittsburghracer]
#2170135
10/08/16 10:27 AM
10/08/16 10:27 AM
Posts: 3,395 Pa
Hot 340
Pa
How much you putting through yours? im at 690 on motor and spraying on top of that. Block is 60 over, not filled, studs, stock caps. Havent seen any signs of an issue, around 20 hits so far. mostly stock 727 never been in it, but has valve body and deep pan. stock a body 8 3/4 housing, spool and 30 spline More details PLEASE. That sucker must be flying with 690 PLUS the hit. x2
[Re: SpareParts]
#2170201
10/08/16 12:23 PM
10/08/16 12:23 PM
Posts: 3,395 Pa
Hot 340
Pa
He claims to street race, doubt he's going to share anything. His first two post in the thread tells most of what his basic combination is. Just not the smaller things
[Re: Hot 340]
#2170265
10/08/16 01:33 PM
10/08/16 01:33 PM
Posts: 20,181 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How much you putting through yours? im at 690 on motor and spraying on top of that. Block is 60 over, not filled, studs, stock caps. Havent seen any signs of an issue, around 20 hits so far. mostly stock 727 never been in it, but has valve body and deep pan. stock a body 8 3/4 housing, spool and 30 spline More details PLEASE. That sucker must be flying with 690 PLUS the hit. x2 What are you a trouble maker. Lol. You are gonna get hollowed at like I did when I asked that question. I haven't had my 60 year old hands slapped in years but he showed me.
#2170344
10/08/16 03:40 PM
10/08/16 03:40 PM
redruM
Columbus, OH
How much you putting through yours? im at 690 on motor and spraying on top of that. Block is 60 over, not filled, studs, stock caps. Havent seen any signs of an issue, around 20 hits so far. mostly stock 727 never been in it, but has valve body and deep pan. stock a body 8 3/4 housing, spool and 30 spline More details PLEASE. That sucker must be flying with 690 PLUS the hit. x2 What are you a trouble maker. Lol. You are gonna get hollowed at like I did when I asked that question. I haven't had my 60 year old hands slapped in years but he showed me. Lol yea I have the twin turbo sbm mustang. Duster is a 422, eagle crank, scat rods, diamond Pistons, 11.4 comp, custom .7xx comp roller, non cnc Indys hand ported then copied in a cnc, ported 360 intake, 950 carb, 2" headers, 3.5 exhaust, big shot plate
[Re: cudaman1969]
#2170466
10/08/16 06:53 PM
10/08/16 06:53 PM
Posts: 43,214 Bend,OR USA
Cab_Burge
What's a safe rpm for stock crank, stock pan as in a stocker engine. I will use the limited collapsing lifters and stocker cam. Guy I bought the heads, intake and cam from said on kill he went 8500. I don't want to be knocking the bearings out, comments? I seriously doubt any SB LA Mopar out there will pull in gear with a hydrauic roller cam and hydraulidc roller lifter and matching valve springs up to or much past 7000 RPM, let alone 8500 in any gear Maybe in nuetral or park I was told by a older guy, drinking Cutty Sark whiskey straight out of a quart bottle at 1:00 PM in the afternoon at the Colorado river back in 1965, that his N/A 392 Hemi motor in his 21 ft. flat bottom V drive Mandella wood hull would peg his 8500 RPM tach I bet him it wouldn't do that so he offer me a ride in it the next morning when he was sober. It would peg the electric tach at 8500 RPM as soon as he went WOT, but it was showing 4300 RPM crusing at around 35 MPH warming up the motor before he hit it hard He had a Vertex magneto on that motor and he should have had a 4 cyl electric tach for it, not a V8 tach. It was reading twice as much RPM when the motor was running, not the true cranksaft RPM it should have been reading. Most of the other, better, high end boats back then had Jones Motorola mechanical tachs driven off of the top of the V drives so they measured the true crankshaft revolutions, not the propeller revolutions. My message is it is easy to be mislead on many things, especaiily automotive racing parts and storys On your deal I would shift it when the motor quits pulling hard in second gear, don't look at the tach before shifting, listen and feel the motor quit pulling first and then look at the tach to see where it quit pulling hard Shift it 200 to 300 RPM before it quits pulling hard Don't over revved it
[Re: Cab_Burge]
#2170604
10/08/16 10:33 PM
10/08/16 10:33 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
What's a safe rpm for stock crank, stock pan as in a stocker engine. I will use the limited collapsing lifters and stocker cam. Guy I bought the heads, intake and cam from said on kill he went 8500. I don't want to be knocking the bearings out, comments? I seriously doubt any SB LA Mopar out there will pull in gear with a hydrauic roller cam and hydraulidc roller lifter and matching valve springs up to or much past 7000 RPM, let alone 8500 in any gear Maybe in nuetral or park I was told by a older guy, drinking Cutty Sark whiskey straight out of a quart bottle at 1:00 PM in the afternoon at the Colorado river back in 1965, that his N/A 392 Hemi motor in his 21 ft. flat bottom V drive Mandella wood hull would peg his 8500 RPM tach I bet him it wouldn't do that so he offer me a ride in it the next morning when he was sober. It would peg the electric tach at 8500 RPM as soon as he went WOT, but it was showing 4300 RPM crusing at around 35 MPH warming up the motor before he hit it hard He had a Vertex magneto on that motor and he should have had a 4 cyl electric tach for it, not a V8 tach. It was reading twice as much RPM when the motor was running, not the true cranksaft RPM it should have been reading. Most of the other, better, high end boats back then had Jones Motorola mechanical tachs driven off of the top of the V drives so they measured the true crankshaft revolutions, not the propeller revolutions. My message is it is easy to be mislead on many things, especaiily automotive racing parts and storys On your deal I would shift it when the motor quits pulling hard in second gear, don't look at the tach before shifting, listen and feel the motor quit pulling first and then look at the tach to see where it quit pulling hard Shift it 200 to 300 RPM before it quits pulling hard Don't over revved it I'll ask him again next time we talk, might have heard him wrong, he was world champion with a Duster out of Balt. about 10 years back. Funny you mention it, I've never watched a tach, except to launch.
#2170609
10/08/16 10:43 PM
10/08/16 10:43 PM
Posts: 3,395 Pa
Hot 340
Pa
