Bell housing dowel pins #216750
02/07/09 04:58 PM
02/07/09 04:58 PM
Lancaster, Pennsylvania
Sweigart1022 Offline OP
Anyone know where I can find the dowel pins that go from the block to the bell housing on a 440 it will be and automatic transmission.
Competitive Suspension Solutions
Re: Bell housing dowel pins [Re: Sweigart1022] #216751
02/07/09 10:28 PM
02/07/09 10:28 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
you can go to lowes or home depot and buy a .500thou steel dowel rod and make your own .
this is cool because you can make them the legnth
that you want , the original pins are .495 so you will need to polish the ones you make down from .500 with some emery cloth on the vise . but it only takes a litle elbow grease to take off .005 .fyi
1969 Dodge Charger 1969 Dodge Superbee
Re: Bell housing dowel pins [Re: Sweigart1022] #216752
02/07/09 10:29 PM
02/07/09 10:29 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
