Just got towed home.( UPDATE) #216667
02/07/09 03:13 PM
02/07/09 03:13 PM
Monee IL
chicagotim2003 Offline OP
Monee IL
Beautiful day here in chicago.I started my car, let it idle for 15 minutes then took a 1 mile drive to the gas station.I filled up, drove about a block to a stop sign and the car died.Still had a strong cranking battery but no start.I`m thinking no spark.What would u try first?
UPDATE!!!!!!!!UPDATE!!!!!!!!!!
This morning i go to the garage.First thing i do is put the battery charger on ,it was run down from trying to start.I check to see if i have power on the ballast and coil both are good.My next move was going to check for spark.As i was about to check for spark the battery became charged so i figured i would just try to turn it over.Boom it fires up and roars like a lion.I let it idle about 10 minutes turned it off and restarted it about 5 times.Seems to be running great.?? I don`t know what to think.
Re: Just got towed home. [Re: chicagotim2003] #216668
02/07/09 03:17 PM
02/07/09 03:17 PM
CHRGR69 Offline
CHRGR69  Offline
What car, engine????
Grandma always said I had "hands of gold"!
Re: Just got towed home. [Re: CHRGR69] #216669
02/07/09 03:20 PM
02/07/09 03:20 PM
Monee IL
Monee IL
Sorry about that. IT`s a 1973 challenger with 440 engine.
Re: Just got towed home. [Re: chicagotim2003] #216670
02/07/09 03:23 PM
02/07/09 03:23 PM
Kirkland, Washington
Pacnorthcuda Offline
Verify its getting spark and fuel. If it checks out OK there you might take a look at a sample of the fuel, or see if it will fire using starting fluid
Re: Just got towed home. [Re: chicagotim2003] #216671
02/07/09 03:30 PM
02/07/09 03:30 PM
CHRGR69 Offline
CHRGR69  Offline
Been there done that with a 73 Challenger. Make sure the firewall main harness contacts are not corroded or fried. Then check the ECU box. What color is it?
Re: Just got towed home. [Re: CHRGR69] #216672
02/07/09 03:59 PM
02/07/09 03:59 PM
Monee IL
Monee IL
I had a extra ballast,coil and ecu.I put those on and nothing.The old ecu was an orange box.New ecu is a regular one.I can see gas squirt when i look down the carb.Next move??? And thanks for the help.
Re: Just got towed home. [Re: chicagotim2003] #216673
02/07/09 04:02 PM
02/07/09 04:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check for spark at the plugs.
Re: Just got towed home. [Re: chicagotim2003] #216674
02/07/09 04:02 PM
02/07/09 04:02 PM
CHRGR69 Offline
CHRGR69  Offline
Spark??
Re: Just got towed home. [Re: chicagotim2003] #216675
02/07/09 04:03 PM
02/07/09 04:03 PM
Are you getting power at the ballast resistor when the key is in the RUN position???????? Check that now. The power for the ignition comes through the firewall (bulkhead) connection block and they are a common failure point on these cars at this age. I even bypassed mine with a separate wire (I don;t like to leave my car on the side of the road or be towed)
Re: Just got towed home. [Re: Pacnorthcuda] #216676
02/07/09 04:10 PM
02/07/09 04:10 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
filed up with diesel... dan
Re: Just got towed home. [Re: ph23vo] #216677
02/07/09 04:12 PM
02/07/09 04:12 PM
Monee IL
Monee IL
Laughed out loud ph23.I just checked the ballast in run position and i had power going to all 4 terminals.Sorry guys i`m a carpenter not a mechanic.
Re: Just got towed home. [Re: chicagotim2003] #216678
02/07/09 04:21 PM
02/07/09 04:21 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Have you pulled a spark plug wire and put an old plug in it and ground it to verify spark? Are you getting power to the coil? check the bulkhead connector? Things to start with that are free.
Re: Just got towed home. [Re: chicagotim2003] #216679
02/07/09 04:23 PM
02/07/09 04:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ok. with the key turned on jump the starter relay to make it crank and see if it starts. There are 2 start circuits one for run and one for start. It's possible to have fire in the run but not start modes.
Re: Just got towed home. [Re: stumpy] #216680
02/07/09 04:32 PM
02/07/09 04:32 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
Been there, done that. Ballast resistor. OOOPS! I missed the part about replacing the ballast. Never mind.
Re: Just got towed home. [Re: stumpy] #216681
02/07/09 04:33 PM
02/07/09 04:33 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Reluctor gap?
Re: Just got towed home. [Re: ph23vo] #216682
02/07/09 04:34 PM
02/07/09 04:34 PM
El Cerrito, by San Francisco
last426 Offline
last426  Offline
First thing I would check. Kim
Re: Just got towed home. [Re: chicagotim2003] #216683
02/07/09 05:02 PM
02/07/09 05:02 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
I had a similar thing happen to my 64 Polara last summer waiting on the road to get into a cruise-in. Car started running a little rough like it was fouling a plug then died. Restarted long enough to get if off the road then died again. My buddy came over and we checked what we could on the roadside, but had to have it towed home. Turned out to be a bad coil (3 month old Accel). Replaced it and everything was fine. Advance stood behind the coil, but of course, did nothing about the $55 tow bill! That's hotroddin', right??
Jeff Adams 64 426 Polara
Re: Just got towed home. [Re: last426] #216684
02/07/09 05:54 PM
02/07/09 05:54 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
As stupid as it sounds, a few months ago a friend did just that in his old 'stang.
Re: Just got towed home. [Re: chicagotim2003] #216685
02/07/09 10:17 PM
02/07/09 10:17 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Monee IL??? Huh. I was at Mom's house there, earlier today. PM sent.
Re: Just got towed home. [Re: chicagotim2003] #216686
02/07/09 10:41 PM
02/07/09 10:41 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
pull the dist cap and spin the motor to make sure the rotor turn if not you have timing chain problem. I had that problem till I decide to pull cap spun the motor rotor didn't move just jiggle sooo I pull the timing cover and saw the cam bolt came lose!
