727 questions #2166600
10/02/16 07:06 PM
10/02/16 07:06 PM
Dillsburg, PA
mrsmallblock Offline OP
Dillsburg, PA
Working on a 727. Aluminum A&A drum so I used stainless stator rings and Teflon input rings. Have never air checked clutches before. But I thought I would this time. You can clearly hear high clutches apply but not the forward... Could it be because of the teflon input rings? Secondly, I had problems with the rear band. Adjusted to 72 inch pounds off 2 turns as usual but can't get any movement on the band. Linkage in correctly and tore it apart and put together again and readjusted but same thing. I have built them before but never had this problem. I am stumped. Any ideas?
Howard
Mrsmallblock
Re: 727 questions [Re: mrsmallblock] #2166607
10/02/16 07:16 PM
10/02/16 07:16 PM
Dillsburg, PA
Dillsburg, PA
Also had a quick question about valve bodies. Deleted the governor with s sleeve. Have TA reverse 17156 valve body but separator plate has whole for governor feed. Should I put a plug in the case?
Howard
Mrsmallblock
