? for those that use e-85/alcohol carbs. #2166176
10/01/16 11:05 PM
10/01/16 11:05 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Is there a lube that you all use on the throttle blades, linkage that's under the throttle bores in the carb.Or do you all that has carbs just remove these carbs and spray something like WD40 in them to keep the corrosion down...........Thaxs wave
Re: ? for those that use e-85/alcohol carbs. [Re: racerx] #2166181
10/01/16 11:22 PM
10/01/16 11:22 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Lucas Safeguard Fuel Conditioner and Stabilizer, 16 oz ,this is your friend.....as per mark sullens using it for 4 years no issues. (wal mart) As far as wd-40 have you ever used it on a firearm not good, turns to a wax like substance ,I would use gun lube for long term storage. but if your talking about short term, I see no problem with wd-40 ...pat
Re: ? for those that use e-85/alcohol carbs. [Re: pattyboy 572] #2166245
10/02/16 01:23 AM
10/02/16 01:23 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I hose mine down with wd40.. before and after every outing.. I'm using a purpose-built prosystems e85 carburetor.. for a year-and-a-half now... and haven't even found anything white fuzz.. Billet aluminum and Brass jets are pretty durable and E85 safe
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: ? for those that use e-85/alcohol carbs. [Re: racerx] #2166966
10/03/16 12:16 PM
10/03/16 12:16 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs for the advice fellas up I purchase some of the Lucas ethanol fuel system stabilizer and i'll see how that works wave
