Restoring original positive battery cable #2166114
10/01/16 09:09 PM
10/01/16 09:09 PM
Ohio
C_B5 Offline OP
C_B5  Offline OP
Ohio
The original positive battery cable on my 72 challenger is in really good condition including the original black tape wrap and part # tag.
The problem is the battery post connector head - the wires are pulling out and are exposed
Mega parts sells just a replacement head that looks close to the factory style and attaches to cable with set screws
Of course it won't look exactly like the original but has anyone repaired the terminal head end in order to retain the original cable ?
Looking for any tips / recommendations
Re: Restoring original positive battery cable [Re: C_B5] #2166233
10/02/16 12:57 AM
10/02/16 12:57 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I tried one of those cable ends. It worked ok but it never was as snug as I would have liked. I still have it around here somewhere as I put a nos cable on in place.
Re: Restoring original positive battery cable [Re: C_B5] #2166236
10/02/16 01:10 AM
10/02/16 01:10 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
We can take your existing cable and cut the damaged head away leaving the exposed wires. Then a correct style head is poured back around the existing cable much as the reproduction or any battery cable for that matter is made. We have done this on several cables both positive and negative so that the car could retain the original cables. There is a difference in what I call the Packard brick red color of an original cable vs the more pinkish red found on the cables on the market today. We have seen on some cables that there is some oxidation of the metal and it has to be trimmed back slightly, but there is most times enough excess not to be an issue. The service runs approximately $35 to replace the head. If it needs to be retaped or the starter lug replaced, it will be slightly more. If you have any questions give me a call or I will be at the Hershey meet and I will be glad to answer any questions.
Richard O'Shields
Restoration Parts and Materials
404-643-5760
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Restoring original positive battery cable [Re: C_B5] #2166947
10/03/16 11:55 AM
10/03/16 11:55 AM
usa
W
whomper1 Offline
whomper1  Offline
W
usa
Richard, that sounds like a great service. can you post some pictures of the finished product?
thank you
Re: Restoring original positive battery cable [Re: whomper1] #2166985
10/03/16 12:47 PM
10/03/16 12:47 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
I am currently out of town getting ready for the Hershey meet, but will attempt to get a before and after picture to post.
Thanks,
Richard
