open up the BL .005 is tight and will howl on coast, take it out toward 0.008, you can almost do that by only taking the cover plate off, easy
Actually final BL came out at .008 after installing the crush sleeve.
Factory states .005-.008, Motive Gear states .007-.009. I went with what the gear vendor stated.
DVW maybe correct (the picture is slightly deceptive as the line where the grease builds up at the root isn't at the bottom) as I have some noise after a long road test.
Going to take a break for now as I'm a little burned out from all the projects of late.
