Is orange RTV ok for Copper head gaskets? #216537
02/07/09 11:25 AM
02/07/09 11:25 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
My block is o-ringed and I'm gonna use copper head gaskets, probably Summit brand.
I know it was mentioned that 'The right Stuff' and some RTV's were ok to seal the water jacket holes. I went to NAPA yesterday to buy the right stuff but was not in the mood to pay $21 for the small tube of it. So I bought orange RTV, will this work ok?
Re: Is orange RTV ok for Copper head gaskets? [Re: ProSport] #216538
02/07/09 11:28 AM
02/07/09 11:28 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Hylomar is the product that was suggested to me for my oringed block. No leaks.
Re: Is orange RTV ok for Copper head gaskets? [Re: ProSport] #216539
02/07/09 11:35 AM
02/07/09 11:35 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
no problems here.
SCE .050 gaskets.
Re: Is orange RTV ok for Copper head gaskets? [Re: ProSport] #216540
02/07/09 11:42 AM
02/07/09 11:42 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
the copper high temp RTV is all i use.
Re: Is orange RTV ok for Copper head gaskets? [Re: blownzoom440] #216541
02/07/09 12:10 PM
02/07/09 12:10 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I also use RTV on all my engines!
Post deleted by Defbob [Re: boatracer572] #216542
02/07/09 02:31 PM
02/07/09 02:31 PM
Re: Is orange RTV ok for Copper head gaskets? #216543
02/07/09 03:13 PM
02/07/09 03:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yamabond, HondaBond, and right stuff are all basically the same thing and way tougher after they dry than RTV.
You can use right stuff for a gasket and it is very tough to get off and with clean dry surfaces it is pretty much never going to leak I have used it for oil pan gaskets and not had them leak at all, also makes great intake end seals.
Re: Is orange RTV ok for Copper head gaskets? [Re: HotRodDave] #216544
02/07/09 03:18 PM
02/07/09 03:18 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I used Yamabond on a set of coppers. Its much different that Right Stuff.
I plan to use yamabond again.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Post deleted by Defbob [Re: CJK440] #216545
02/07/09 03:39 PM
02/07/09 03:39 PM
Re: Is orange RTV ok for Copper head gaskets? #216546
02/07/09 04:46 PM
02/07/09 04:46 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Is the Yamabond cheaper than the right stuff? Is it easier to clean off, or the same? Where is it sold?
Post deleted by Defbob [Re: ProSport] #216547
02/07/09 05:27 PM
02/07/09 05:27 PM
Re: Is orange RTV ok for Copper head gaskets? #216548
02/07/09 05:36 PM
02/07/09 05:36 PM
O'Fallon,IL.
70RTRacer Offline
70RTRacer  Offline
O'Fallon,IL.
Like DusterDave said Yamabond is the best way to go. The stuff just flat works.
Re: Is orange RTV ok for Copper head gaskets? [Re: 70RTRacer] #216549
02/07/09 05:48 PM
02/07/09 05:48 PM
Columbus Ohio
Moore & Moore Offline
Columbus Ohio
I use permatex avaition form-a-gasket around the water jackets. I have never used RTV on copper gaskets.
Jack
Re: Is orange RTV ok for Copper head gaskets? [Re: Moore & Moore] #216550
02/07/09 06:36 PM
02/07/09 06:36 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'll probably cop some crap for this but i use roofing silicon on my gaskets. it's high temp as i use it to coat header gaskets so they can be reused multi times, they seal the water jackets everytime no leaks & best of all a quick rub down with petrol or carb cleaner & they clean up nicely. 2 of my crew are automotive specialists & when i first showed them what i was useing they cringed. but 5 years later they are sold on roofing silicon. 1 of my crew was a hardcore "3 bond" user claiming it was the best(it's like yamabond) but these days i see he's opted for roofing silicon too. and the best part, it's dirt cheap!
deit- just reading the label it says it's good for aluminium, copper, lead & tin & sticks to galvanising & powder coated materials. the price on the tube is $3.99 & thats our $ not usd.
Re: Is orange RTV ok for Copper head gaskets? [Re: Moore & Moore] #216551
02/07/09 06:38 PM
02/07/09 06:38 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
so what have we learned here today kids? absolutely nothing! just make sure you use the sealer of your choice. most will work just fine
Re: Is orange RTV ok for Copper head gaskets? [Re: ProSport] #216552
02/07/09 07:30 PM
02/07/09 07:30 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
1. It really is worth it
2. Stop being cheap.
I used Yamabond on the first 2 Cometic installs I've done, both with fresh aluminum heads. 1st one was sloppy, but it didn't leak (on a BB). Second one was neater but it leaked (on a SB). I'm... not going to be using that stuff again, it's really nasty to work with and hard to apply properly. The time it takes to properly apply it to all 4 surfaces of the head, gasket and block causes it to dry significantly in my experience. It's like working with a runny salt-water taffy .
Props to all that use it successfully, too much of a pain for me though .
Re: Is orange RTV ok for Copper head gaskets? [Re: ProSport] #216553
02/07/09 08:42 PM
02/07/09 08:42 PM
ELYRIA,OH
ELYRIA,OH
here is 1 tip for all aplications.use sparingly around the oil holes to the head or it will get blocked or the plug will get pushed into the valvetrain and block oiling there.i hope you wont have to pull the heads to redo things.it is a bummer.
Re: Is orange RTV ok for Copper head gaskets? [Re: ProSport] #216554
02/08/09 11:06 AM
02/08/09 11:06 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
3bond makes yamabond and hondabond, it's all the same stuff. I've used it for years to seal the engine cases on harleys (no gasket, crappy machining) I seemed to have the only bikes that didn't "mark their spot". It works but you better be sure you put it where you want it 'cuz it's not easy to remove. I personally realy like hylomar....
