Re: D100 Charging Woes
[Re: Andrewh]
#2164746
09/29/16 10:42 PM
09/29/16 10:42 PM
RapidRobert
I would undo the bypass & rehook the alt black output line to the bulkhead. What Andrew said, with the key on, the blue wire at the alt field terminal and the blue wire at the reg should both be hot. the green wire from the other alt field terminal to the other (green wire) terminal at the reg should have continuity to each other in that green line. reg must have a good ground & I missed if you had replaced it or not. other than that all that is left is the alt (if the above check out we can test the alt). when we get it charging put the battery on a charger to get it back up as opposed to letting the alt charge it in the vehicle. holler back when you can. short version: bad alt (possibly brush related)/bad reg/reg ain't grounded/blue wire to reg and or alt is open/open in green wire from alt to reg.
[Re: elmor353]
#2164810
09/29/16 11:56 PM
09/29/16 11:56 PM
RapidRobert
Alright lets see if we can speed this up, see if the blue wires are hot & if so, see if the green wire has continuity
[Re: elmor353]
#2164985
09/30/16 09:58 AM
09/30/16 09:58 AM
Andrewh
so you need a multi meter to run some tests. hopefully you have one, if not they should be under 10 bucks at most places.
So lets run through how this works to make sure we all understand what happened.
you had a 100 amp alt. Based on the year of the truck, it should be a dual field alt. you replaced it with a 60 amp you had laying around. Again, please let us know if it was a dual field alt as well? Just making sure.
This suddenly stopped charging as far as you know.
There are 3 wires to a dual field alt. 2 field wires and then the big post out of the back of the alt.
1 field wire goes back to the VR. This should be some value less than 12 volts with the key on. 1 field wire is battery voltage with key on.
the big alt wire you have said you wired directly to the starter relay, on the big stud there, which also has a wire directly back to the battery.
This should also read battery voltage, with or without the key on.
The original wire that used to go here, you have removed. you still have power to the inside of the cab which means you still have power going in. This is really independent of the charging system, other than the key on parts.
[Re: Andrewh]
#2165131
09/30/16 02:36 PM
09/30/16 02:36 PM
RapidRobert
I would hook the black wire from alt back to the bulkhead & disconnect the bypass (from alt to battery or relay). this will let the ammeter read honest since you dont have a meter so we can easily tell when it we get it charging then you can reinstall the bypass if desired. do you have a 1157 dual filament taillight bulb & socket & pigtails handy in your parts pile that you could use to check if the blue wire ign1 circuit is hot at the alt and reg with key on? then when solved you can reinstall the 100 amp alt if desired (I hear it is a pretty trouble free unit). As said a ten dollar HF multimeter will suffice & if you buy something else, their coupons might let you have it for free
[Re: Andrewh]
#2166164
10/01/16 10:45 PM
10/01/16 10:45 PM
RapidRobert
ammeter bypassed is unrelated. we'll assume the new alt/new reg are functioning and that bolting on the new reg took care of it possibly being ungrounded. all that is left (if above are OK) is are they being fed (blue wire circuit) and green wire continuity between the two. with all that confirmed it MUST charge.
[Re: elmor353]
#2167495
10/04/16 02:10 AM
10/04/16 02:10 AM
RapidRobert
field wires switched on alt field terminals-no problem. blue/green switched on reg-big problem (if it full fields tho likely it would just be a no charge which is far better than full fielding), tho not likely on them cuz the reg triangle connector/pigtails are blue/green. holler back. EDIT blue goes to either alt field terminal and to the "top" reg triangle terminal with it facing up like a pyramid. green goes to the "side" reg terminal and the other alt field terminal.
[Re: elmor353]
#2170089
10/08/16 02:55 AM
10/08/16 02:55 AM
RapidRobert
When the truck is running, with the headlights and blower on, I have 12.5 volts at the battery. When I turn the lights and blower off, I get 12.9 at the battery. Any thoughts? it still ain't charging unfortunately. the headlites/blower are draining the batt then when you shut em off it stops the drain & lets the batt voltage come back up a bit just because the drain from the batt has been stopped. EDIT normal charging voltage is gonna be at least in the 13's
[Re: elmor353]
#2170157
10/08/16 11:16 AM
10/08/16 11:16 AM
Posts: 5,812 ohio
ruderunner
ohio
Key on not running, do you have battery voltage at the blue wire on the alternator? If not you have a broken wire or poor connection in that circuit.
Engine running, use a jumper wire to ground the other terminal at the alternator (where the green wire would go). Measure voltage at the battery, should be quite high, 16 or better. Be quick about this as the overcharge can damage components.
This is called "full fielding" the alternator and tests to see if it capable of charging.
If you don't have overcharge at the battery, check the voltage at the alternator output stud "fat wire". If you have high volts there then the problem is bad wiring between the alt output and battery positive, including the bulkhead connection and ammeter.
Also won't hurt to check voltage between the alternator case and battery negative, this will show a ground problem.
Ran into this on my 89 d350. Had 21 volts at the alternator! 12 at the battery. Found a corroded connection in the charging wire.
Angry white pureblood male
[Re: ruderunner]
#2170278
10/08/16 01:43 PM
10/08/16 01:43 PM
RapidRobert
What Ruderunner said: full field the alt for 5 seconds max, just long enough to take a voltage reading from alt batt stud to alt case. run it at a fast idle & have all lights/accessories off. Tho on the test I would pull both field leads & jump from batt positive post to one male alt field stud and as said ground the other male alt field stud.
