Brake Drums. factory painted or not ? #2164186
09/29/16 08:42 AM
09/29/16 08:42 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
I'm doing some detailing work on my 68 Superbee.
Question. Are the brake drums painted from the factory? If so what color?
Or are they just plain metal ?
Thank You
Keeping the Bee Buzzin'
Re: Brake Drums. factory painted or not ? [Re: Simonic] #2164193
09/29/16 09:04 AM
09/29/16 09:04 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Just plain metal unless they had road wheels. Then the drum face (not the whole drum) is painted red.
Re: Brake Drums. factory painted or not ? [Re: Simonic] #2164353
09/29/16 01:38 PM
09/29/16 01:38 PM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Thank you.I do have road wheels.Any idea on what sort of shade of red would be acceptable/correct?
Re: Brake Drums. factory painted or not ? [Re: Simonic] #2164415
09/29/16 03:05 PM
09/29/16 03:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The actual original color is the subject of debate.
Re: Brake Drums. factory painted or not ? [Re: John_Kunkel] #2164452
09/29/16 04:03 PM
09/29/16 04:03 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Admiration For Multiple Carburetor Vehicles...
Re: Brake Drums. factory painted or not ? [Re: Simonic] #2164727
09/29/16 10:23 PM
09/29/16 10:23 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Judging by the date that they changed the colors - which pretty much correlates with model year changeover - I'd theorize that they used PP1 for '68s and then R6 for '69s.
If someone can match those part #s with a paint code, that'll likely tell.
I have dim memories of seeing the red drum faces back in the day, but not enough to prove anything as far as color.
Re: Brake Drums. factory painted or not ? [Re: Simonic] #2164973
09/30/16 08:48 AM
09/30/16 08:48 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Many original red paint drums still out there but of course 50 years of fade makes things inconclusive at best. Batalson has "drum" paint for sale but it may be for 70 and up, but I'd check with him.
I usually blast and paint my drums a cast iron color so they don't rust, then apply the red.
Careful, your character's showing!
Re: Brake Drums. factory painted or not ? [Re: Simonic] #2165084
09/30/16 01:17 PM
09/30/16 01:17 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
RestoRick also has a red drum paint I believe.
Re: Brake Drums. factory painted or not ? [Re: Simonic] #2169057
10/06/16 04:57 PM
10/06/16 04:57 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
Road wheels (beauty ring Magnums) weren't available in '68 were they? I thought the only 5 spoke available in '68 was the Magnums?
I also always thought the red drum thing started in '69 with Road wheel?
I know at least in '70 it was the Road & Rally wheels that got it.
John Kunkel, what's the date on that schematic. Pretty sure Hemigeno found an earlier version to the current one that's floating around. 8-15-69?
The one Geno found is dated 2-19-68 but Road wheels weren't available in '68.
I ended up using a PHerd engine red. So, so many restorations are done by spraying the red on. Imo, if you're gonna do it, do it right & brush it on sloppily. With my former '70 Charger R/T, the paint must have still been wet since 2 wheels had drips on them.
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: Brake Drums. factory painted or not ? [Re: Simonic] #2169662
10/07/16 03:17 PM
10/07/16 03:17 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I used Rustoleum spray paint red . . .
Re: Brake Drums. factory painted or not ? [Re: a12rag] #2169757
10/07/16 05:49 PM
10/07/16 05:49 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My '71 Barracuda with 14" Ralleye's had it brushed on all 4 drums. Very sloppy and very little. Not sure it would have even shown through?!
'63 Dodge 330
11.19 @ 121 mph
Re: Brake Drums. factory painted or not ? [Re: 472 R/T SE] #2175173
10/15/16 11:59 AM
10/15/16 11:59 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Originally Posted By 472 R/T SE
Road wheels (beauty ring Magnums) weren't available in '68 were they? I thought the only 5 spoke available in '68 was the Magnums?...
The one Geno found is dated 2-19-68 but Road wheels weren't available in '68...
Chrysler called both versions of the wheels, with or without trim rings, "Road Wheels". So "Road Wheels" were available starting with the '67 model year.
I know "Magnum" is a term we commonly use, but as far as I know, Chrysler never used that name for them.
Below is info from the '68 and '69 Chrysler data books and price lists.
beer
Re: Brake Drums. factory painted or not ? [Re: Simonic] #2183233
10/26/16 08:25 PM
10/26/16 08:25 PM
472 R/T SE Offline
472 R/T SE  Offline
I'll be darned. So Chrysler called the beauty ring-less 5 spoke, Road, in '68. 1st I've seen of that, way cool, thanks for posting that.
Interesting how both of the wheels are listed under hubcaps & wheelcovers instead of separating them.
Chrysler R/T Club
[/color]
