You lose by my calculation between 0.060 and 0.080 installed height. Depending on your lift rules, you may have trouble finding a valve spring strong enough that'll fit in that small distance without coil bind.
However, Comp Cams is now recommending running springs to the minimum allowable height whenever possible as it damps out spring harmonics. At least that's what I remember.
Hughes 1110 springs is where I'd be looking.
Another concern is valve head shape. The Hemi head may require a different head shape than a wedge, like tulip instead of nail head, something like that. The wrong head shape may negate any flow increase from diameter increase. Or not.
R.
