Dana 60 cover? #2163142
09/27/16 08:51 PM
09/27/16 08:51 PM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
Who makes a good cover for a Dana 60?
Thanks for any and all info
Kevin
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163165
09/27/16 09:10 PM
09/27/16 09:10 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I like my new Strange cover. Aluminum powder coated black.
[image][/image]
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163223
09/27/16 10:10 PM
09/27/16 10:10 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I got one of these nice thick polished stainless ones.
https://m.summitracing.com/parts/ktl-304m60
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163226
09/27/16 10:10 PM
09/27/16 10:10 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
LPW.
69 GTX 68 Road Runner
Re: Dana 60 cover? [Re: JERICOGTX] #2163228
09/27/16 10:15 PM
09/27/16 10:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
LPW Ultimate 60 support cover works well and doesn't leak twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163260
09/27/16 10:46 PM
09/27/16 10:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have the cheapo chrome cover. It's light, looks decent, and doesn't leak.
Doug
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163285
09/27/16 11:13 PM
09/27/16 11:13 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
May be overkill but I really like these. twocents
Moser Rear End Cover for Dana 60
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163295
09/27/16 11:19 PM
09/27/16 11:19 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I painted the stock, thick non leaking cover.
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163304
09/27/16 11:28 PM
09/27/16 11:28 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My S-60 came with a nice chrome cover, never could keep the bas#*rd from leaking. I ordered a factory Dana cover and all is well.
Re: Dana 60 cover? [Re: justinp61] #2163336
09/28/16 12:06 AM
09/28/16 12:06 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I cleaned up and painted a stock cover. It even has the tab to help locate the brake line.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163339
09/28/16 12:09 AM
09/28/16 12:09 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
That moser cover has the cap supports built in, a stock steel cover is 1/8" thick and thicker only adds weight....tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Dana 60 cover? [Re: astjp2] #2163366
09/28/16 12:36 AM
09/28/16 12:36 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
If I get a free minute tomorrow, I'll let you know what the weight difference is between the stock one and the Moser. up Maybe someone can get a weight on the LPW cover also for comparison. work
For what it's worth, I think the additional weight of the bearing cap supports is offset by the added strength they provide. twocents
Re: Dana 60 cover? [Re: MadMopars] #2163370
09/28/16 12:42 AM
09/28/16 12:42 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
That and the extra weight is pretty much EXACTLY where you want it.
I just weighed an extra stock steel cover with plug on my postal scales. 2 lbs.9 oz.
'63 Dodge 330
11.19 @ 121 mph
Re: Dana 60 cover? [Re: MadMopars] #2163412
09/28/16 01:36 AM
09/28/16 01:36 AM
fresno ca
mikeysmopars Offline
fresno ca
I think if your using a Trans Brake, this is a must, footbraking or occasional trip to the track maybe not but the extra support on those main caps is nice! twocents
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163520
09/28/16 09:58 AM
09/28/16 09:58 AM
an8sec70cuda Offline
The best to get is a thick aluminum cover like the Moser or Ultimate w/ the main cap preloaders. Some cars have issues w/ fitting them if you still have a stock fuel tank. That's the only reason I don't have one...was scared it wouldn't fit.
I just have a typical chrome cover on mine...no issues at all running mid 9s and now high 8s at 3900 lbs for the past 13 years.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163582
09/28/16 11:16 AM
09/28/16 11:16 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IMO if you have to run a cover with a built in brace/cap loading bolts to make your properly set up Dana live you need different rear end. I know several guys running fast heavy cars with trans brakes and stamped covers for years with no problems.
Re: Dana 60 cover? [Re: justinp61] #2163641
09/28/16 12:44 PM
09/28/16 12:44 PM
Rittman Ohio
Rittman Ohio
This is true but when I built the Dana in my heavy stick shift car I noticed how thin the factory Dana bearing caps were and in my opinion they need help. I thought to either replace the caps or add some additional support would be a good idea.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Dana 60 cover? [Re: fourgearsavoy] #2163655
09/28/16 01:04 PM
09/28/16 01:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: Dana 60 cover? [Re: 604 Hemi GTX] #2163936
09/28/16 09:01 PM
09/28/16 09:01 PM
sgcuda Offline
sgcuda  Offline
You mean like this?
Re: Dana 60 cover? [Re: sgcuda] #2163954
09/28/16 09:27 PM
09/28/16 09:27 PM
I'm almost certain that the stock caps on all the Dana 60 are cast steel just like the center section are,not cast iron that breaks easier work shruggy My current bracket car has Mark Williams steel caps on boths sides with a LPW caluminum cover with the preload bolts, probally way over kill for what I'm doinng with this car shruggy
