Re: Running too cool...
[Re: Publicbottle]
#2163318
09/28/16 12:42 AM
09/28/16 12:42 AM
RapidRobert
Maybe I should try another 185 stat first ? I would, (Keep It Simple Sam). If you are sure the gauge is correct (I dont trust em to be dead on). 160 is too cool & will cause fuel atomization problems. poor mileage/fuel wash. a 190/195 would be even better & reconfigure the fan however which way it needs to be to deal with it
[Re: Publicbottle]
#2163583
09/28/16 12:17 PM
09/28/16 12:17 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Ya I considered the gauge too, but my heater doesn't put out any heat so I ruled that out. So, if I install a 195 stat, my elect fan on/off switch choices seem to be 185 or 195. Wouldnt run this setup cause the fan to run constantly?
That's what I think would happen...don't want that. Maybe I should try another 185 stat first ? Why not pull the stat and see what it is FIRST instead of assuming what you installed ?
[Re: Publicbottle]
#2163590
09/28/16 12:28 PM
09/28/16 12:28 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
That's what I think would happen...don't want that. Maybe I should try another 185 stat first ? Even at 160° your heater should put out plenty of heat. My Dart has a 160° stat in it and the heater works good. I drove it yesterday and it ran about 170° in 75° or so air temps.
[Re: Publicbottle]
#2163672
09/28/16 02:21 PM
09/28/16 02:21 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
That's what I think would happen...don't want that. Maybe I should try another 185 stat first ? That is one definate advantage to adjustable fan controllers. The OFF temperature must be higher than the thermostat temperature to avoid running the fan onto a radiator that is not flowing coolant.
[Re: Publicbottle]
#2164809
09/29/16 11:55 PM
09/29/16 11:55 PM
Posts: 7,664 IN
ahy
IN
looks like the thermostat was at fault, i remember buying a mr.gasket brand stat now, and it even has 180 stamped on it. installed a 195 stat (stant) and it runs much warmer now, but will prob switch it out for a 185 as my fan setup is causing the fan to run constantly at 195. 185 should work with my current fan thermostatic switch.......hopefully? The Mr Gasket stats earned a reputation for problems... though the one I had for a while was fine. 180 degrees is a standard temp and probably fine for your application. A standard 180 stat from the AP store should do well unless you are running a high volume water pump. With high volume pump a high flow stat is recommended. I am currently running the Milodon high flow 180 stat from Mancini w/o issue.
