Will a tranny crossmember from a 73/4 fit a 71 charger ?
#2162806
09/27/16 02:27 PM
09/27/16 02:27 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I'm referring to the part that holds tranny up with the 4 bolts that go through the frame I thought one from a cuda was same as my 71 charger but cuda is too short The charger measure about 18 1/2 inches from outside hole to outside holes. Cuda is 15 1/2 inches
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Will a tranny crossmember from a 73/4 fit a 71 charger ?
[Re: toplescuda]
#2163098
09/27/16 08:40 PM
09/27/16 08:40 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Buddy of mine sent pic of a 73 satellite. The crossmember was gone. But the part it bolted to looks nothen like the 71 So it seams I'm stuck with 71-72 b body?? Thought since the floor structure was same as e body crossmember be same But there sure not
[Re: toplescuda]
#2163143
09/27/16 09:51 PM
09/27/16 09:51 PM
Posts: 338 Bellevue,Mich.
Dodge33
Bellevue,Mich.
73-74 b-body the torsion bars anchor in a crossmember that is behind the actual crossmember.the torsion bars go thru the actual crossmember. Hope this makes sense. Crossmembers are the same for the transmission.
[Re: Dodge33]
#2163544
09/28/16 11:31 AM
09/28/16 11:31 AM
DaytonaTurbo
Manitoba, Canada
73-74 b-body the torsion bars anchor in a crossmember that is behind the actual crossmember.the torsion bars go thru the actual crossmember. Hope this makes sense. Crossmembers are the same for the transmission. The transmission does not bolt to isolated torsion bar crossmember. It bolts to the original crossmember as it did in 71/72.
