I think a found something good in trunk of my challenger?? #2162998
09/27/16 06:10 PM
09/27/16 06:10 PM
Albuquerque, New Mexico
moparmatt Offline OP
There was a set of small block heads in my 73 challenger when i purchased last feb, 360 AAWJ on head are these T/A heads? I know it says 360 but I think they are good??
Re: I think a found something good in trunk of my challenger?? [Re: moparmatt] #2163021
09/27/16 06:42 PM
09/27/16 06:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What's the casting number?
You realize that the T/A heads were slightly differently machined than the regular production heads, both using the same castings.
Don't be the exception.
Re: I think a found something good in trunk of my challenger?? [Re: moparmatt] #2163037
09/27/16 06:54 PM
09/27/16 06:54 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Take a photo of the top that shows the intake ports & & push rod holes then post it.
Re: I think a found something good in trunk of my challenger?? [Re: Alaskan_TA] #2163692
09/28/16 02:48 PM
09/28/16 02:48 PM
dogdays Offline
dogdays  Offline
I'm all for you finding a treasure, but the odds are something like 10,000 to 1 against you.
AFAIK the AAWJ is a foundry mark, found on many different Mopar castings.
The desirable heads would have the pushrod holes mostly out of the intake port walls. That's the only difference of which I'm aware.
See attached picture, pay special attention to the pushrod holes.
BTW, congratulations on owning a Challenger. That's getting harder and harder to do.
R.
