Re: best carb for a 440
[Re: moparmatt0]
#2162138
09/26/16 04:58 PM
09/26/16 04:58 PM
fast68plymouth
So. Burlington, Vt.
Quick fuel "Q-850". Those have the 1.750 throttle bore with a 1.400 Venturi.
[Re: moparmatt0]
#2162186
09/26/16 05:59 PM
09/26/16 05:59 PM
Thumperdart
State of confusion
850 dp minimum imo.............
[Re: Thumperdart]
#2162433
09/26/16 11:11 PM
09/26/16 11:11 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
850 dp minimum imo............. the right foot determines how far the throttle plates are opened, even at WOT Every Mopar B or RB motor I've palyed with loved more air and fuel, even sixpaks or tunnel rams
[Re: moparmatt0]
#2162438
09/26/16 11:21 PM
09/26/16 11:21 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I agree with ^^ these guys as well and 850 will allow you to make a few other mods to the engine retaining the carb.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: moparmatt0]
#2162448
09/26/16 11:46 PM
09/26/16 11:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
One thing no one has asked.. is this a trans brake or foot brake car.. a trans brake can use a big carb but a foot brake car you have to have good throttle response to get the rpm... I was running a 1050 on a 405ci but with a trans brake
[Re: moparmatt0]
#2162449
09/26/16 11:47 PM
09/26/16 11:47 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
My 440 has run best using a 750 Holley DP carb.The 850 didn't work as well.
[Re: Chris2581]
#2162457
09/26/16 11:54 PM
09/26/16 11:54 PM
Posts: 4,700 Wichita
GY3
Wichita
I have an 850 Speed Demon on a very similar combo. It starts, runs and drives flawlessly. Very happy with it.
[Re: StealthWedge67]
#2162771
09/27/16 01:32 PM
09/27/16 01:32 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
The smallest carb I'd run on a healthy 440 would be an 830.
[Re: moparmatt0]
#2162780
09/27/16 01:41 PM
09/27/16 01:41 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
I took a 950 off my little 318 and put on a 750, slowed the car down a tenth. Picked it right back up putting 950 back on. So with a bigger motor I suspect the results would favor a bigger carb
[Re: moparmatt0]
#2162781
09/27/16 01:42 PM
09/27/16 01:42 PM
Posts: 2,094 central texas
krautrock
central texas
i just picked up an 830Hp 4150 for cheap, then started doing some reading, it has the 1.56" venturi.
i would maybe look for a holley 950DP, as the venturi is smaller than the 830 and 850 holley carbs, might work better. maybe consider picking up a clean used one (any of the above ^) and send it to Thumprdart to get adjusted...
[Re: fullmetaljacket]
#2162943
09/27/16 05:10 PM
09/27/16 05:10 PM
Posts: 31,069 Oregon
AndyF
Ran an 830 DP years ago on a mild stock bore 440 with a 528 flat tappet purple cam. 10.1 compression and it ran great on the street and track at 3600 + lbs. I'd think that you would want to run an Edelbrock carb on your setup since they weigh a lot less than a Holley. (although the newest all aluminum Holley carbs are getting to be fairly lightweight)
[Re: AndyF]
#2162995
09/27/16 06:07 PM
09/27/16 06:07 PM
Thumperdart
State of confusion
I surely wouldn't recommend a carb based on weight and NOTHING including efi out performs a Holley carb in single and dual applications.........
