best carb for a 440 #2162065
09/26/16 03:00 PM
09/26/16 03:00 PM
NY
moparmatt0 Offline OP
NY
I have a 67 gtx with a 440 with 440 source heads and 10.1 compression it has a 557 lift soild mopar cam and a m1 intake 4:56 gears rarly driven on the street what would be the best carb thanks for the help.
Re: best carb for a 440 [Re: moparmatt0] #2162087
09/26/16 03:36 PM
09/26/16 03:36 PM
AndyF Offline
AndyF  Offline
Sounds like maybe 550 hp type engine so I'd go with a 750DP carb. An 850DP might make a little more top end power.
You could contact BradH and offer to do some carb testing for him. Might be a win/win for you guys!
Re: best carb for a 440 [Re: moparmatt0] #2162138
09/26/16 04:58 PM
09/26/16 04:58 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quick fuel "Q-850".
Those have the 1.750 throttle bore with a 1.400 Venturi.
Re: best carb for a 440 [Re: moparmatt0] #2162164
09/26/16 05:34 PM
09/26/16 05:34 PM
Minnesota, USA
minnesota guy Offline
Minnesota, USA
I have a 500HP 440 in my 71 Cuda. Old school set up with 520 hyd Racer Brown cam and Holley SD. I own both the 750 and 850 DP. Playing with both jetting, they are so close it was no longer worth my time swapping back and forth.
If you have a choice--the 750DP will be better. Chuck Lofgren verified this when he was running his 70 440 Cuda at BIR.
Provided you are in the old school build type.
Re: best carb for a 440 [Re: moparmatt0] #2162186
09/26/16 05:59 PM
09/26/16 05:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
850 dp minimum imo.............
Re: best carb for a 440 [Re: Thumperdart] #2162433
09/26/16 11:11 PM
09/26/16 11:11 PM
iagree
the right foot determines how far the throttle plates are opened, even at WOT work
Every Mopar B or RB motor I've palyed with loved more air and fuel, even sixpaks or tunnel rams shruggy
Re: best carb for a 440 [Re: moparmatt0] #2162438
09/26/16 11:21 PM
09/26/16 11:21 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I agree with ^^ these guys as well and 850 will allow you to make a few other mods to the engine retaining the carb.
1963 Plymouth Max Wedge
1971 Barracuda
Re: best carb for a 440 [Re: moparmatt0] #2162448
09/26/16 11:46 PM
09/26/16 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One thing no one has asked.. is this a trans brake
or foot brake car.. a trans brake can use a big carb
but a foot brake car you have to have good throttle
response to get the rpm... I was running a 1050 on
a 405ci but with a trans brake
wave
Re: best carb for a 440 [Re: moparmatt0] #2162449
09/26/16 11:47 PM
09/26/16 11:47 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My 440 has run best using a 750 Holley DP carb.The 850 didn't work as well.
Nautilus Racing-
Re: best carb for a 440 [Re: Chris2581] #2162457
09/26/16 11:54 PM
09/26/16 11:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have an 850 Speed Demon on a very similar combo. It starts, runs and drives flawlessly. Very happy with it.
'63 Dodge 330
11.19 @ 121 mph
Re: best carb for a 440 [Re: moparmatt0] #2162768
09/27/16 01:31 PM
09/27/16 01:31 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
My own experience would suggest you'll be leaving a LOT on the table with a 750. My 451 has an 830DP on it and it runs pretty good on the street, but I suspect it could be making more power up top at WOT with a bigger carb. OP is running 4.56's and an M1, both of which want RPM's. I would be thinking 850 minimum, larger (4150 -1000) would likely make more power and be my choice, especially for a car that is used almost solely at the track as the OP describes.
twocents
Re: best carb for a 440 [Re: StealthWedge67] #2162771
09/27/16 01:32 PM
09/27/16 01:32 PM
an8sec70cuda Offline
iagree The smallest carb I'd run on a healthy 440 would be an 830.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: best carb for a 440 [Re: moparmatt0] #2162776
09/27/16 01:39 PM
09/27/16 01:39 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If it really is not driven much on the street, and mostly a track car, then use a big carb. I like the 950-1,000 HP type with annular boosters.
Re: best carb for a 440 [Re: moparmatt0] #2162780
09/27/16 01:41 PM
09/27/16 01:41 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I took a 950 off my little 318 and put on a 750, slowed the car down a tenth. Picked it right back up putting 950 back on.
So with a bigger motor I suspect the results would favor a bigger carb
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: best carb for a 440 [Re: moparmatt0] #2162781
09/27/16 01:42 PM
09/27/16 01:42 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i just picked up an 830Hp 4150 for cheap, then started doing some reading, it has the 1.56" venturi.
i would maybe look for a holley 950DP, as the venturi is smaller than the 830 and 850 holley carbs, might work better.
maybe consider picking up a clean used one (any of the above ^) and send it to Thumprdart to get adjusted...
Re: best carb for a 440 [Re: moparmatt0] #2162856
09/27/16 03:51 PM
09/27/16 03:51 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Years ago I ran a 850DP on a very mild 440 and it worked great. My 434 small block has a BLP main body with 1.590" venturi on a holley 1.75 base plate and works great for street/strip, according to BLP it's 1050-1100 cfm.
Re: best carb for a 440 [Re: justinp61] #2162911
09/27/16 04:41 PM
09/27/16 04:41 PM
fullmetaljacket Offline
Ran an 830 DP years ago on a mild stock bore 440 with a 528 flat tappet purple cam. 10.1 compression and it ran great on the street and track at 3600 + lbs.
Re: best carb for a 440 [Re: fullmetaljacket] #2162943
09/27/16 05:10 PM
09/27/16 05:10 PM
AndyF Offline
AndyF  Offline
I'd think that you would want to run an Edelbrock carb on your setup since they weigh a lot less than a Holley. (although the newest all aluminum Holley carbs are getting to be fairly lightweight)
Re: best carb for a 440 [Re: AndyF] #2162995
09/27/16 06:07 PM
09/27/16 06:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I surely wouldn't recommend a carb based on weight and NOTHING including efi out performs a Holley carb in single and dual applications.........
Re: best carb for a 440 [Re: AndyF] #2163030
09/27/16 06:51 PM
09/27/16 06:51 PM
Andy.
That was before I got the 1 Flu over the cuckoos nest weight loss sickness.
