INITIAL AV GAS IMPRESSION..............
#2161507
09/25/16 06:08 PM
09/25/16 06:08 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
So I got 10 gallons of the 100ll for $39.00 and took it for a putt on my sun beer run just for an idle cruise feel. It does run a bit richer at idle and cruise but not bad and the drop in gear is a bit tighter than the 101 unleaded VP. Smells great though and will do some high speed blasts tomorrow and plug readings. Someone mentioned adding Marvel Mystery oil stating av gas doesn't have good lubricating properties any truth to that............
Re: INITIAL AV GAS IMPRESSION..............
[Re: Thumperdart]
#2161613
09/25/16 10:00 PM
09/25/16 10:00 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
Do they add Marvel Mystery Oil to the gas tank of an airplane?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2161656
09/25/16 11:07 PM
09/25/16 11:07 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Do they add Marvel Mystery Oil to the gas tank of an airplane? A lot of people do actually, I used to but then I just quit because I began running mogas in my airplane...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Thumperdart]
#2161683
09/25/16 11:49 PM
09/25/16 11:49 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
. Someone mentioned adding Marvel Mystery oil stating av gas doesn't have good lubricating properties any truth to that............ "Someone" doesn't know sh1t from canned rhubarb.
Mo' Farts
Moderated by "tbagger".
[Re: astjp2]
#2161799
09/26/16 03:37 AM
09/26/16 03:37 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
Do they add Marvel Mystery Oil to the gas tank of an airplane? A lot of people do actually, I used to but then I just quit because I began running mogas in my airplane... I remember hearing of Mogas in Germany when I was in the Army in 1968, what is it? As fas adding oil to airplane fuel it ain't needed Them motors have no valve seals, are loose as all get out and normally and regulary consume from 1/4 quart to 1 quart of oil per hour or higher at low steady state RPM compared to our street and strip motors My Lycoming O 540 C.I. 260 HP would blow the first quart out in a hour if I ran it one quart low from being full, it would blow the next quart out in two to three hours of steady flying if I ran it down 2 quarts from full. It had a 12 quart system stock, I even treid running it down to 8 quarts cold before starting and that helped a little bit more on reducing the oil consumption, but I figure for the price of one quart of avaition oil I would run it at 9 quarts cold on take off for any long trips
[Re: Chris2581]
#2161894
09/26/16 11:28 AM
09/26/16 11:28 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
Don't add anything to it.
[Re: 71birdJ68]
#2161940
09/26/16 12:31 PM
09/26/16 12:31 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
This is an interesting thread as there are 3 small air fields within 5 miles of my ranch. My car runs OK on pump93 but I would rather put it away for the winter with the good gas in it Thanks Dom ! Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 71birdJ68]
#2161961
09/26/16 01:04 PM
09/26/16 01:04 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Know how to make a small fortune in aviation? Probably the same formula as trucking. Start with a large one. Kevin
