Re: Leash Electronics
[Re: dart440_72]
#2161261
09/25/16 10:50 AM
09/25/16 10:50 AM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
I have one of his 12 relay boards and just purchased a dual 70 amp board for my fuel pumps. Nice products and I have had zero trouble after 18 months and a few thousand miles. On my twelve relay board the key he sent for how it was wired was wrong, it had two colors flipped but I noted it and it wasn't an issue.
68 Barracuda Formula S 340
[Re: dart440_72]
#2161375
09/25/16 02:30 PM
09/25/16 02:30 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I have run his stuff for quite a few years. It has been nice seeing his products evolve to their current status.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Dragula]
#2161403
09/25/16 03:05 PM
09/25/16 03:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
One thing I dont like about all these panels is that they put the relays all in one spot.. I prefer the relay near the load item and run a thin trigger wire to it
[Re: dart440_72]
#2161413
09/25/16 03:16 PM
09/25/16 03:16 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I wire several cars each year and for the price point the Leash products are hard to beat. I have had zero issues with Randy's Westmoreland's (Leash) products. With that said if your budget will allow Speedwire makes the best products on the market IMO.
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: MR_P_BODY]
#2161434
09/25/16 03:58 PM
09/25/16 03:58 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
One thing I dont like about all these panels is that they put the relays all in one spot.. I prefer the relay near the load item and run a thin trigger wire to it I agree, I just run a double relay to the two big items, fuel pump in back, fan in front, those are where I use the single Leash relay panels, my main panel is a ARC 8000
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#2161851
09/26/16 09:38 AM
09/26/16 09:38 AM
Posts: 19,402 north of coder
moparx
One thing I dont like about all these panels is that they put the relays all in one spot.. I prefer the relay near the load item and run a thin trigger wire to it I agree, I just run a double relay to the two big items, fuel pump in back, fan in front, those are where I use the single Leash relay panels, my main panel is a ARC 8000 are you saying you run the relay on the panel, then run a small diameter trigger wire to the second relay at the pump and fan ?
[Re: dart440_72]
#2161879
09/26/16 11:02 AM
09/26/16 11:02 AM
Posts: 577 Arkansas
Adrielp
Arkansas
Good Products, simplified our rewiring project. We've got the old sportsman board, a high output relay, and fuse block.
Adriel Paradise Substation Design Engineer III
[Re: dart440_72]
#2161893
09/26/16 11:26 AM
09/26/16 11:26 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Used a couple of their nitrous boards...good stuff.
[Re: an8sec70cuda]
#2162381
09/26/16 10:18 PM
09/26/16 10:18 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I like the terminations on speedwire panels. Relays near pump or fans is senseable. Especially high current items. Fuel pumps pull less than five amps. OEM has engine related relays up front.
One pet peeve is a relay in the transbrake feed. Dumb dumb dumb. In my line of work we have to test timing of relays. It takes very little change in temperature to effect release time. Furthermore if you race pro tree. Yeah yal go ahead put an extra relay in that circuit lol.
Why would you relay panel and relay again a circuit? Just remove the one on the panel and jump out.
