T440 e #2161007
09/24/16 07:46 PM
09/24/16 07:46 PM
CT
moparpaul66 Offline OP
CT
Just got a 440 block with T440 E stamped on the pad. What year is this? My book says 4T is 74 but I don't have the 4.... E is cast crank...
Thanks guys!
Re: T440 e [Re: moparpaul66] #2161009
09/24/16 07:51 PM
09/24/16 07:51 PM
I would look on the side (I forget which side) of the block for the actual block casting date such as: 09*27*73
Re: T440 e [Re: moparpaul66] #2161025
09/24/16 08:18 PM
09/24/16 08:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Look closely, there should be either a single digit or letter in front of the T....probably lightly stamped or full of paint.
Re: T440 e [Re: moparpaul66] #2161163
09/25/16 01:22 AM
09/25/16 01:22 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I had one that was stamped T440 E and it was a 1978 motor home engine. Had tapered seat 5/8 hex spark plugs and a cast crank.
