Page 10 of 12 1 2 8 9 10 11 12
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159344
09/22/16 12:51 PM
09/22/16 12:51 PM
Parts unknown
590 Challenger Offline OP
Parts unknown
Q1A double adjustable, what is a good starting point for me?
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159354
09/22/16 12:58 PM
09/22/16 12:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its stock valving you will be NEAR max tight if
not full tight on extension.. each car will want what
it wants.. so you cant just say one thing for all..
but that part of the fun of tuning the chassis.. a strong
solid chassis(very little flex) is easier to tune that a
car that flexes... video is you best friend on chassis work
wave
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159369
09/22/16 01:09 PM
09/22/16 01:09 PM
Parts unknown
Parts unknown
ll my drag radial guys concur, they say to tighten it up. Thanks everyone
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159389
09/22/16 01:26 PM
09/22/16 01:26 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A good starting point is get on the phone and order some shocks........but until then tighten the QA-1s to full tight on front extension
Re: Challenger inner fender wells....remove? [Re: Monte_Smith] #2159395
09/22/16 01:29 PM
09/22/16 01:29 PM
Parts unknown
Parts unknown
lol, yes sir
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159412
09/22/16 01:41 PM
09/22/16 01:41 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I guess the Santhuff are for the rear.
My rears are 6 sweeps up top from full tight and 6 to 7 clicks from full tight on the bottom.
I have strange struts up front. But I'm in the middle of the adjustments.
Re: Challenger inner fender wells....remove? [Re: FastmOp] #2159418
09/22/16 02:02 PM
09/22/16 02:02 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That's probably why yours is hard to tune as well. That loose strut is letting it bury the back tire
Guys over look this one simple thing. The STIFFER you can make the suspension, both front and rear, the FASTER the car will be provided it hooks. Yet guys always start way loose and then stop when it "works", never going further to see if it works "better". Start STIFF, then if it doesn't wad the tire or do something, soften it up. You will find the sweet spot MUCH quicker than you will starting in "dishrag" mode
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159426
09/22/16 02:15 PM
09/22/16 02:15 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
They are on the list for this winter. I called strange right after I posted to see what the top and bottom adjusters did. I Went and tightened it as tight as I can get it on top. Not sure where to set the bottom compression. It's the Koni cartridge
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159515
09/22/16 04:41 PM
09/22/16 04:41 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
SOME Strange struts, depending on the cartridge are clockwise for full tight and some are counter clockwise for full tight. Make sure you have that straight
Re: Challenger inner fender wells....remove? [Re: Monte_Smith] #2159519
09/22/16 04:49 PM
09/22/16 04:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah.. mine are CCW for full stiff and I keep forgetting
that.. on the Rampage.. CW on the race car
wave
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159603
09/22/16 07:16 PM
09/22/16 07:16 PM
Parts unknown
Parts unknown
OK, full tight on extension, check
No one mentioned compression at all.......?
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159656
09/22/16 08:51 PM
09/22/16 08:51 PM
K
Kiddart Offline
Kiddart  Offline
K
I watched you run at milan on sept 2nd. what rpm do you leave at?? Sounds like you are leaving around 6k?? then it shoots way up cuz you spin, not sure how you can calm that down dut it sounds scary like you are going to explode the motor.
Thank you
Kiddart
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159673
09/22/16 09:14 PM
09/22/16 09:14 PM
Parts unknown
Parts unknown
it was set at 3,000 the first two passes, I was desperate and tried 4,200 the last pass. I don't believe it ever went past 7,200, limiter is set at 7,400. I never stayed in it at all, makes a lot of noise, leaves the line with 29 pounds of boost
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159937
09/23/16 09:29 AM
09/23/16 09:29 AM
Parts unknown
Parts unknown
Front shock compression,
There was no mention of it. How do I tell if I have it right? full tight too? Will that cause the car not to settle back down?
Starting point, 1/2 tight? 3/4, full?
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159950
09/23/16 10:24 AM
09/23/16 10:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted By dvw
Mine are nearly full tight as well. Even Dizusters car on no prep last Thursday at Milan was -8/40 from full tight on the front rebound.
Doug
Doug, are yours that tight to keep it from climbing or to give it more traction?
My front end seldom rises more than a foot. The tires stay on the ground the first 6 feet or so. Hooks better tight. Loose just causes it to unload the rear quickly after the hit. If it wasn't in bracket mode I'd tighten it even more.
Doug
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159969
09/23/16 11:22 AM
09/23/16 11:22 AM
Parts unknown
Parts unknown
It’s come a long way from when it did the Pro Street thing before reconstruction. The first time I took it to the track I was told it launch like a scared cat. Back then all four tires came off the ground at the hit. I’ll start close to full tight. Thanks guys, I will let you know how it goes next week
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159984
09/23/16 11:55 AM
09/23/16 11:55 AM
K
Kiddart Offline
Kiddart  Offline
K
I will be watching from the stands. I can try to get some video if I can get close enough to get some during Time trials
Thank you
Kiddart
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2159996
09/23/16 12:05 PM
09/23/16 12:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Start at 1/2 way on compression.. make sure it will
settle down but not bouncy
wave
Re: Challenger inner fender wells....remove? [Re: Kiddart] #2160115
09/23/16 02:20 PM
09/23/16 02:20 PM
Parts unknown
Parts unknown
That would be great, thank you. We will also be putting two go-pros under it
Re: Challenger inner fender wells....remove? [Re: 590 Challenger] #2160672
09/24/16 05:47 AM
09/24/16 05:47 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If that motor makes ANY power.........29 lbs of boost, drag radials and a clean leave are words that will NEVER fit together in a sentence, don't care what you do with shocks and suspension
