Removing zinc #2160270
09/23/16 05:53 PM
09/23/16 05:53 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Anyway to remove zinc plating at home that doesn't involve media blasting.
Re: Removing zinc [Re: 71birdJ68] #2160274
09/23/16 06:00 PM
09/23/16 06:00 PM
Kirkland, Washington
Pacnorthcuda Offline
Soaking in vinegar works. Muriatic acid works too, and is faster
Re: Removing zinc [Re: Pacnorthcuda] #2160281
09/23/16 06:10 PM
09/23/16 06:10 PM
Morristown Tn.
Morristown Tn.
I was wanting to do a set of Eddie carbs, will the muriatic acid eat the bodies up? Trying to re plate them in the correct color, or as close as I can get to it.
Re: Removing zinc [Re: 71birdJ68] #2160288
09/23/16 06:16 PM
09/23/16 06:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Muriatic acid will eat aluminum pretty fast. You could try brushing some of it on and cleaning it off as soon as the plating is gone. It won't take long. I'd try it on a test piece if you have one. Wood bleach(oxalic acid)works good at cleaning corroded aluminum. I haven't tried it on zinc plating. That would be safer for the aluminum.
Re: Removing zinc [Re: burdar] #2160307
09/23/16 06:36 PM
09/23/16 06:36 PM
Morristown Tn.
Morristown Tn.
Wonder if the bodies are zinc, or aluminum? They are like new, just trying to disguise them a little. Maybe I'll do the vinegar like he said.
Re: Removing zinc [Re: 71birdJ68] #2160436
09/23/16 09:53 PM
09/23/16 09:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe the bodies may be zink, I have an old AFB here that was in a wrecked car and has a corner broken off, it sure looks more like a zink material then aluminum, at the break.
An Eddie could be nearly anything. Gene
Re: Removing zinc [Re: 71birdJ68] #2160453
09/23/16 10:11 PM
09/23/16 10:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Removing zinc [Re: Supercuda] #2160586
09/24/16 12:46 AM
09/24/16 12:46 AM
Morristown Tn.
Morristown Tn.
Edelbrock thunder series.
Re: Removing zinc [Re: 71birdJ68] #2160590
09/24/16 12:54 AM
09/24/16 12:54 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Still just aluminum
Re: Removing zinc [Re: 71birdJ68] #2160616
09/24/16 01:41 AM
09/24/16 01:41 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Alumi prep. Available from most auto body supply shops.
