Replacement engine #2160086
09/23/16 12:48 PM
09/23/16 12:48 PM
71ragtop Offline OP
71ragtop  Offline OP
I have a car build date of 11/69 the original motor is gone'what months replacement block would be considered date correct?
Re: Replacement engine [Re: 71ragtop] #2160092
09/23/16 12:52 PM
09/23/16 12:52 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That's hard to say but most people use 2 month as a rule thumb.
There is no guarantee that your car was actually built 11/69.
Also the engine assembly date is a far better indicator that the block casting date.
Re: Replacement engine [Re: 71ragtop] #2160099
09/23/16 01:04 PM
09/23/16 01:04 PM
71ragtop Offline OP
71ragtop  Offline OP
Two months backwards and forward or just backwards
Re: Replacement engine [Re: 71ragtop] #2160104
09/23/16 01:07 PM
09/23/16 01:07 PM
dogdays Offline
dogdays  Offline
Well, seems to me that it ain't natural for an engine to be produced after the car is built, so I would say before.
The engine's assembly date is part of the Engine ID Number, stamped into a machined pad in various places on the front of the engine, depending on the engine family.
R.
Re: Replacement engine [Re: dogdays] #2160135
09/23/16 01:41 PM
09/23/16 01:41 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
R.
Sorry. Yes two months before hand.
The engine build dates stamped based on family. Small blocks are below the drives side head, big blocks are usually on the ID pad near the distributor, and HEMIs are on the oil pan surface at the back of the block on the passenger side.
The closest date as to when your car was made is probably the date on the front of the K member.
Re: Replacement engine [Re: 71ragtop] #2160141
09/23/16 01:46 PM
09/23/16 01:46 PM
71ragtop Offline OP
71ragtop  Offline OP
Thanks for all of your input,you've educated me again.
Re: Replacement engine [Re: 71ragtop] #2160171
09/23/16 02:14 PM
09/23/16 02:14 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
Here's a few things to consider:
It's never going to be 100% correct because the original is gone. So, what is the next best thing? THAT is the question.
Typical Choices:
* Casting date within a reasonable range before the cars SPD (usually 1-6 months for non Hemi engines), better yet, same block with an assembly date within 1 week-3 months before the SPD of your car.
* Warranty/Service replacement block, casting and assembly dates are less important since replacement would have taken after the car was built so the casting date could before the cars SPD, or many months or even years after the SPD.
So which one is better? Well, tough call.....The warranty engine is going to have stampings and small details that are somewhat different than an assembly line installed engine, the used origial is going to have the VIN# of another car stamped into it (So the "Ghost" of another cars DNA will forever haunt you!).
laugh2
