Would You Use This Spindle? #2159774
09/22/16 11:30 PM
09/22/16 11:30 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Got a pair of disc spindles off of a '71 Coronet in a 'yard. After cleaning 'em up found one has rust pitting on the shaft, but none on the bearing surface. It extends all the way around the shaft. Ok to use? Let the debate begin.
Re: Would You Use This Spindle? [Re: vdriver] #2159781
09/22/16 11:44 PM
09/22/16 11:44 PM
BDW Offline
BDW  Offline
Why not? No issue in that area
Re: Would You Use This Spindle? [Re: vdriver] #2159809
09/23/16 12:13 AM
09/23/16 12:13 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Looks OK to me?
Re: Would You Use This Spindle? [Re: 451Mopar] #2159813
09/23/16 12:16 AM
09/23/16 12:16 AM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Originally Posted By 451Mopar
Looks OK to me?
Me too.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Would You Use This Spindle? [Re: vdriver] #2159818
09/23/16 12:21 AM
09/23/16 12:21 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I would use that, not a problem.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Would You Use This Spindle? [Re: vdriver] #2159822
09/23/16 12:25 AM
09/23/16 12:25 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes, and if there was to be pitting, that is the least stressed section IMO.
Re: Would You Use This Spindle? [Re: vdriver] #2159848
09/23/16 01:00 AM
09/23/16 01:00 AM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Thanks guys. bow
Re: Would You Use This Spindle? [Re: vdriver] #2159874
09/23/16 02:05 AM
09/23/16 02:05 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Another vote for using it.Rocky
Chrysler Firepower
Re: Would You Use This Spindle? [Re: vdriver] #2159957
09/23/16 10:52 AM
09/23/16 10:52 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Pitting on the bearing surface wouldn't be an issue either - the bearing doesn't spin on the spindle. The seal area is what you have to be concerned with. FWIW, mine are way worse than that.
Re: Would You Use This Spindle? [Re: Stanton] #2160098
09/23/16 02:01 PM
09/23/16 02:01 PM
dogdays Offline
dogdays  Offline
I'm not convinced that that area was bright and shiny on the spindle when new. I suspect it's an area where the forging was only big enough for the machining to take off the top of the bumps, leaving the bottom of the bumps as-forged. In service that area is usually covered with grease.
R.
Re: Would You Use This Spindle? [Re: vdriver] #2160136
09/23/16 02:41 PM
09/23/16 02:41 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No issue with that. USE IT!
Re: Would You Use This Spindle? [Re: dogdays] #2160165
09/23/16 03:07 PM
09/23/16 03:07 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
R.
Hmmm....never thought of that. I was wondering how it could have gotten rusty in the first place, since it should been covered in grease.
Re: Would You Use This Spindle? [Re: vdriver] #2160204
09/23/16 04:00 PM
09/23/16 04:00 PM
crlush Offline
crlush  Offline
Yup I'd use it
Re: Would You Use This Spindle? [Re: vdriver] #2160247
09/23/16 05:00 PM
09/23/16 05:00 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Nope. I know the stresses are not great in that area, but that pitting is a great source for stress risers. Significantly increases the chances of cracking and breaking. I personally would not risk it.
Re: Would You Use This Spindle? [Re: markz528] #2160292
09/23/16 06:20 PM
09/23/16 06:20 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
That's exactly what I was wondering about when I posted this.
Re: Would You Use This Spindle? [Re: vdriver] #2160410
09/23/16 09:02 PM
09/23/16 09:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Grind them out then.
Re: Would You Use This Spindle? [Re: cudaman1969] #2160441
09/23/16 10:01 PM
09/23/16 10:01 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Sorry, but we are starting down a path that could very well make this worse for the OP. It appeared to me, and not if addressed already, seems like the spindle has already had some mechanical surface de rust prep in posted pic. That was smart, and only improved matters. Going further with grind marks, causing minor localized heating, and/or grind marks orientation, etc, are a risk, and not worth it. Additionally any metal removal is hard to see as a plus. If there was one or two serious depressions, which I don't see, there would be the issue of concentrated stress riser. The fact that there are numerous rust cavities, actually spreads the stress out over a larger surface area, minimizing any single large stress concentration. As also already mentioned, I always coat the area shown pitted with grease, for this very reason, due, to exposure some how, by immersion, or condensation.
Re: Would You Use This Spindle? [Re: jcc] #2160480
09/23/16 10:30 PM
09/23/16 10:30 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Granted the stresses are much higher, but in my career I have seen many rotating shafts break because of stress rises caused by that kind of corrosion. Each one of those pits has stress risers.
Re: Would You Use This Spindle? [Re: markz528] #2160492
09/23/16 10:39 PM
09/23/16 10:39 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes, I agree, but I believe I have taken that into account correctly in my thinking. On a related note, ever seen a fully "knurled" (literally hundreds of stress risers) rear axle shaft, and know why?
Re: Would You Use This Spindle? [Re: vdriver] #2160527
09/23/16 11:33 PM
09/23/16 11:33 PM
BDW Offline
BDW  Offline
Stress risers......... You realize these are forged steel, not cast?
