Re: which sump for lo deck A body [Re: turbo toad] #2035142
03/20/16 04:22 PM
03/20/16 04:22 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
yes, that is the pan and i was wrong on the price. thats the pan i would like to try. will that pan work with my combo?
Re: which sump for lo deck A body [Re: mopar dave] #2035181
03/20/16 05:53 PM
03/20/16 05:53 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I used that pan in my 440 dart, revving to 6700 for over 5 yrs and i intend to use it with my low deck stroker as well.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: which sump for lo deck A body [Re: deaks] #2035205
03/20/16 06:32 PM
03/20/16 06:32 PM
Mt Morris Michigan
Mt Morris Michigan
cool, sounds like a good pan.
Re: which sump for lo deck A body [Re: mopar dave] #2035348
03/20/16 10:10 PM
03/20/16 10:10 PM
AndyF Offline
AndyF  Offline
I have this pan for sale in the race section. It came out of a BB A-body car. The pan had to be modified to clear the idler arm. That is one thing to watch out for in an A body car, it the pan doesn't have that clearance then you'll need to be modify the pan.
Re: which sump for lo deck A body [Re: AndyF] #2035400
03/20/16 11:05 PM
03/20/16 11:05 PM
Mt Morris Michigan
Mt Morris Michigan
Didnt know those pans needed clearancing like that for A body. Do all bb pans need mods like that to fit A bodies?
Re: which sump for lo deck A body [Re: mopar dave] #2035480
03/21/16 12:45 AM
03/21/16 12:45 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The factory type pans are IIRC "187" and "499" part numbers. they have a feature that's not as deep, and more rounded to clear the idler arm.
Re: which sump for lo deck A body [Re: mopar dave] #2035491
03/21/16 01:04 AM
03/21/16 01:04 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Every pan needs some kind of clearance for a bb a body, or you lose some turning. Im not sure if the cheap deep sump pans on eBay clear or not but they have the whole right side bent up to clear. Are you using 67-72 or 73+ steering?
Re: which sump for lo deck A body [Re: JAMESDART] #2035500
03/21/16 01:17 AM
03/21/16 01:17 AM
Mt Morris Michigan
Mt Morris Michigan
yes 67 barracuda factory steering.
Re: which sump for lo deck A body [Re: mopar dave] #2035594
03/21/16 10:05 AM
03/21/16 10:05 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Yeah you need a clearanced pan. If you can't weld, just buy the pan from andyf. Ive seen some guys that still had to ad more clearance to the c body pans,while!e it worked for others. I think the 73+ steering may clear a pan with no notch but I'm not positive, it wont swap over to a 67 k frame without cutting and welding anyway. On my 74 duster I used the c body pan that I put a baffle in, just because I had it, I don't think it needed it.
Re: which sump for lo deck A body [Re: AndyF] #2159285
09/22/16 10:55 AM
09/22/16 10:55 AM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Yep! Had to do that with my 440 source Pan. Also cut out and reboxed K frame.I had a little more of a problem because of girdle. (dropped things down a little more)
Re: which sump for lo deck A body [Re: dare_dude] #2159722
09/22/16 10:17 PM
09/22/16 10:17 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Milodon Road Race pan, low profile with great baffling. You MAY need to clearance the K-member, The k members are not very consistent in construction. The only downside of the Milodon pan is they aren't cheap, but neither are engines....whistling
Re: which sump for lo deck A body [Re: AndyF] #2159733
09/22/16 10:30 PM
09/22/16 10:30 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
A 440source pan hit the K-frame significantly (B engine in stock position with AR motor plate) and I didn't feel like notching the K. I tried a Milodon center sump pan and it did fit (barely), but still bumped the steering linkage in the area shown.
So I clearanced it with a BFH. hammer Looks ugly but nobody can see it under there anyway!
Although if it ever comes off again I'll have someone cut & weld a neat notch like Andy's cool
Re: which sump for lo deck A body [Re: mopar dave] #2159782
09/22/16 11:48 PM
09/22/16 11:48 PM
Hot Rod Ridge
FastmOp Online tonguue
FastmOp  Online Tonguue
Hot Rod Ridge
Milidon road race pan on my 68 Valiant
Re: which sump for lo deck A body [Re: mopar dave] #2160595
09/24/16 01:05 AM
09/24/16 01:05 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I am using the Milodon 7qt with external oiling. Part Number 30931.
Engine is a low deck stroker, stock steering box and idler, QA1 upper and lower control arms. Factory 318 torsion bars... Lakewood scatter shield with Jerico 4-Speed.....
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: which sump for lo deck A body [Re: Skeptic] #2160718
09/24/16 10:41 AM
09/24/16 10:41 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Another vote for the road race pan. I went through 2 7 qt pans, 1 Milodon, 1 Moroso due to ground clearance issues (admittedly we live on a road that people with Jeeps comment on its condition). If I had bought the road race pan it would have cost the same as the total of the two pans plus I still had to bu the road race pan. This is on a 70 Road Runner so can not speak to K members, steering etc. Even on the B body it would have been easier to install from underneath with that pan but hopefully you install the engine on an irregular basis..... Once in no issues on the clearance front.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: which sump for lo deck A body [Re: David_in_St_Croi] #2160740
09/24/16 11:23 AM
09/24/16 11:23 AM
Mt Morris Michigan
Mt Morris Michigan
This is the pan CAB sold me. says it fits A body with least resistance. I haven't installed it yet.
