Re: which sump for lo deck A body
[Re: mopar dave]
#2033691
03/18/16 11:45 AM
03/18/16 11:45 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Most center sump pans will work,but the distance from the front pan rail to the sump I think has to be 5". This means the oil pan for a E-body like the Milodon 6qt unit wont work.
[Re: mopar dave]
#2033868
03/18/16 03:49 PM
03/18/16 03:49 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
I used a Mopar low profile 6 quart 1970/71 Hemi and 440 6 pak oil pan in my old Duster, I did slide the motor back one inch with elephant ears up front and I had to slot the stock V8 tranny mount to make it fit that way I did need to grind a tiny little bit, around a 1/4 inch, off of the K member rear lip on the passenger side front edge that was near the oil pan corner I also slid the rear end forward one inch with ladder bars and coil overs while stretching the rear wheel wells so I could put a bigger rim and tires on it for the increase power That car was almost 50 % weight on the front and back with me in it
[Re: mopar dave]
#2033872
03/18/16 03:55 PM
03/18/16 03:55 PM
Posts: 4,209 New York
polyspheric
New York
If you have a choice among more than 1 that fits, you want: 1st: deepest "full" level and lowest pickup position 2nd: highest volume up to the pan rail (not just to the "full" level)
Boffin Emeritus
[Re: mopar dave]
#2033960
03/18/16 06:25 PM
03/18/16 06:25 PM
Chris2581
Jacksonville, FL
Moroso 8 ot pan fits,as does the Mopar 6 qt. Milodon has the pan that is a low profile,it fits too.I've used all 3 pans I've mentioned in a BB/A body car.
[Re: mopar dave]
#2034612
03/19/16 06:36 PM
03/19/16 06:36 PM
Chris2581
Jacksonville, FL
Same pan on Ebag from KMJ Performance...about 80 bucks...
[Re: mopar dave]
#2034667
03/19/16 08:37 PM
03/19/16 08:37 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What is your intended RPM ?
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: mopar dave]
#2034885
03/20/16 06:00 AM
03/20/16 06:00 AM
Posts: 368 michigan
turbo toad
michigan
moneys very tight right now with this build. starting from cratch sucks, so will be getting the moroso 8qt pan Chris mentioned. found it at jegs for $134. very affordable right now. thanks Dave you wouldnt happen to have a link to this pan would you?
Check out my build on Facebook Ttoad Hurley its updated regularly
