Re: motor mounts
[Re: mhutch1948]
#2159834
09/23/16 12:44 AM
09/23/16 12:44 AM
Posts: 10,670 Freeport IL USA
poorboy
Freeport IL USA
What ever you do, you will probably have to add brackets on the frame to attach to the mounts on the motor.
By the 55/56/57, you could buy a Dodge or a Plymouth with a V8. Those original parts may still be available, but how well they will attach to your mid 80s motor might be a good question. I've not dealt with a 55 dodge car, 50, 54, and 55 Dodge trucks, but they have a different frame then the cars do. Does you car have a transmission mount at the rear of the transmission? Trucks do not.
Also, what are your plans for a transmission for the 318? The original trans would have had an emergency brake drum on the end of the trans. You will loose that, and you will probably want/need to update the rear axle as well. There are web sites that deal with this specific era of cars, I'd Google search. Gene
Re: motor mounts
[Re: mhutch1948]
#2160520
09/23/16 11:31 PM
09/23/16 11:31 PM
Posts: 7,506 Az
Crizila
Az
has any body put a mid 70s to late 80s 318 in a 55 dodge - Plymouth car with out the front clip change? if so what engine mounts did you use? I have had a hard time finding the steel mounts for a 318 truck . I think this is a way to go. just a thought , so where can I find steel mounts for a 70s 318 truck , then buy the rubber mounts to finish it off. thanks mike mhutch1948 360 stock motor mounts. Fabbed brackets to the frame.
Fastest 300
Re: motor mounts
[Re: mhutch1948]
#2160992
09/24/16 07:00 PM
09/24/16 07:00 PM
Posts: 26,037 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If I were doing it, I'd use the later spool mounts (won't pull apart under torque) and fabricate frame brackets to accept them.
Re: motor mounts
[Re: cogen80]
#2196696
11/15/16 12:16 PM
11/15/16 12:16 PM
Posts: 7,506 Az
Crizila
Az
Nice, but a little pricey.
Fastest 300
Re: motor mounts
[Re: mhutch1948]
#2196708
11/15/16 12:31 PM
11/15/16 12:31 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Guess they don't know that the 273/318 driver's side ears are wider apart than the 340/360, unless they expect you to fab up a spacer but they make no mention of that.
Re: motor mounts
[Re: 67R/T4speeder]
#2197328
11/16/16 01:53 PM
11/16/16 01:53 PM
Posts: 7,506 Az
Crizila
Az
Not much insulation with those Tinman ones, but nice having them available. That's why I went with stock motor mounts. Figured there would be enough vibration coming from "other areas" and wasn't concerned about ripping one apart with 300 - 350 HP level my motor would be making. My focus on my build was "driver friendly".
Fastest 300
Re: motor mounts
[Re: mhutch1948]
#2202013
11/24/16 08:52 PM
11/24/16 08:52 PM
Posts: 8 mineola texas u.s.a.
mhutch1948
hey crizila; your set-up (very nice, great pics) is what I am thinking for my dodge car. cant seem to find that style of motor mount. I can use the spools on my current motor, and I can cut the mounts off the k-member from the 5th ave but the other way seems easier to me. I understand that I may have to move the 318 to the right 1-1 1/2in for manifold clearance.i plan on using the 904 trans and mybe the rearend also. thank you; mike
Re: motor mounts
[Re: mhutch1948]
#2202403
11/25/16 04:02 PM
11/25/16 04:02 PM
Posts: 7,506 Az
Crizila
Az
hey crizila; your set-up (very nice, great pics) is what I am thinking for my dodge car. cant seem to find that style of motor mount. I can use the spools on my current motor, and I can cut the mounts off the k-member from the 5th ave but the other way seems easier to me. I understand that I may have to move the 318 to the right 1-1 1/2in for manifold clearance.i plan on using the 904 trans and mybe the rearend also. thank you; mike Don't know what you want to use for ex. manifolds, but I went with block hugger headers and had plenty of room to put my motor centered in the frame rails. Bigger issue might be the steering gear box / steering shaft. A rack eliminated the gear box clearance issue, so I just had to contend with the steering shaft. Cleared the headers bay about 1" - passing through the left motor mount. Make sure you have clearance with the steering system before you start welding up the mounts. My engine mount bolt holes are slotted so I can make minor side to side engine levelling adjusting if necessary. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
Fastest 300
