Re: D100,150,200,250? What's the difference?
[Re: DaytonaTurbo]
#2159541
09/22/16 05:23 PM
09/22/16 05:23 PM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
When the EPA handed out their rules (restrictions) for the D100 and W100, Chrysler started calling the trucks D150 and W150 to avoid the EPA regulations for a while so they had more time to meet their rules.
[Re: DaytonaTurbo]
#2159759
09/22/16 11:14 PM
09/22/16 11:14 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
My 75 W100 was the heavier version, technically it was a W150. It had a 6100 gvw, so that way it didn't have to have any emissions equipment on it. Mine had no egr valve, sealed fuel system, etc.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: 79powerwagon]
#2159961
09/23/16 11:05 AM
09/23/16 11:05 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
The difference between a 100 and 150 is simply the year of manufacture.
Many years they made both the 100 and 150.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: Soopernaut]
#2160089
09/23/16 01:50 PM
09/23/16 01:50 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Many years they made both the 100 and 150. This is true. I have a '82 D150 and a '84 D100. The difference is GVW rating. In the mid '70s, catalytic convertors were required on trucks if they were under a certain GVW. Bumping the GVW up on a D100 to a new D150 model exempted the need for a CC. Eventually the CC requirement GVW was raised over the years. The last year the D150 was exempt was 1978, '79 150s had CCs. The D250 and 350 exemption went into the '80s. I had a '84 D350 that came without CCs.
[Re: DaytonaTurbo]
#2160144
09/23/16 02:48 PM
09/23/16 02:48 PM
Posts: 5,956 ohio
ruderunner
ohio
Had an 89 w350, factory non cat. Dual smog pumps though.
Angry white pureblood male
[Re: DaytonaTurbo]
#2163230
09/27/16 11:17 PM
09/27/16 11:17 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
In the beginning the 00 were the base rating/component trucks, the 50 were the HD version of that series meaning Bigger Alt, Trans, Fuel tank, Radiator, Diff, tires and payload just to some of the upgrades. As the series number got bigger the upgrades also included frame construction (taller, thicker and even double walled) eventually they dropped the 00 and just added HD packages. This was a manufacturing cost savings ( brochures, emblems ect...) and also led the less informed consumer assume all trucks were equal and I just remembered here is the ratings "in the beginning" D/W 100 = 1/4 ton D/w150 = 1/2 ton D/w200 = 3/4 ton D/W 300 = 1 ton The 250 and 350 badging didn't start till mid to late 70's for example I owned a '74 D300 with a 10000lb GVW and a 83 D350 with a 8750 GVW
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: DaytonaTurbo]
#2163738
09/28/16 04:10 PM
09/28/16 04:10 PM
Soopernaut
Des Moines IA
The 1st year of the D150 was 1977. I had one with the 8 3/8 rear axle from the factory. There were D100s with the 9.25. The same transmission was available in both, fuel tank sizes were not dependent on truck weight, alternators were optional, the same spring capacities were available on the D100 and D150, tires and wheels were the same size, the frames were the same, etc.
From the brochure: *All D100 models include Evaporative and Exhaust Emission Control System. All D150,D200 and D300 models include heavy-duty Exhaust Emission Control System.
[Re: 79powerwagon]
#2164168
09/29/16 06:42 AM
09/29/16 06:42 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
D 100/150 trucks are 1/2 ton 2wd. W 100/150 trucks are 1/2 ton 4x4. D200/250 are 3/4 ton 2x4 W200/250 are 3/4 ton 4x4 and so on.
The difference between a 100 and 150 is simply the year of manufacture. Ford became an F150, Dodge followed suit. GM jumped from 10 to 1500, and Dodge followed that (later). GM went from 10 to 15
[Re: DaytonaTurbo]
#2164965
09/30/16 07:46 AM
09/30/16 07:46 AM
Posts: 5,956 ohio
ruderunner
ohio
Not so sure about that. Buddy of mine had a 78 W300 with a 440. He ordered it new, kept it till he passed away about 7 years ago.
Always garage kept, wish I had it.
[Re: DaytonaTurbo]
#2165929
10/01/16 03:21 PM
10/01/16 03:21 PM
W.I.N. Racing
Byron, NY
I presume he meant the D100 couldn't be purchased with a BB but the rest could.
[Re: W.I.N. Racing]
#2177495
10/18/16 03:17 AM
10/18/16 03:17 AM
Posts: 6,570 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I presume he meant the D100 couldn't be purchased with a BB but the rest could. What years are you referring to? I had a 67 D100 that had a 383 and have seen many Sweptlines so equipped. Kevin
[Re: d-150]
#2178529
10/19/16 01:21 PM
10/19/16 01:21 PM
Twostick
Still wishing...
Still wishing...
My bad meant difference in 100 and150.and yes there was a special package 100 with 383 but couldn't get a 440.of course 3/4 ton and up could b had with big block If you mean a CSS, mine was just a custom cab D100. No CSS. There is a 70 or 71 D100 local to me that is a 383/727 with A/C and power steering. Kevin
