How to check for stall (converter) Schooling needed. #2157842
09/19/16 11:46 PM
09/19/16 11:46 PM
west palm beach, florida
modelmakerinc Offline OP
What is the procedure to check the stall speed of a converter?
How to figure out "flash"
Thank you in advance
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2157860
09/20/16 12:19 AM
09/20/16 12:19 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
To tell where the convertor hits/ flashes at, I put the car in high gear, and at a slow roll stab the pedal hard, watch the tach.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2157864
09/20/16 12:21 AM
09/20/16 12:21 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I agree... that's the easiest way to do it. It MIGHT very quickly pass that number on a hard launch, but it will settle back into the number you see on the tach like Don says.
Good way to see where you're at without a data logger or a playback tach.
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2157964
09/20/16 08:23 AM
09/20/16 08:23 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My favorite way is to point a video camera at the tachometer and watch it in slow motion but you can also do it the way these guys suggested, just don't do it too long or too often as it is not very good for the converter, my 8" ATI actually said not to do that in the instructions but we all do it.
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2157966
09/20/16 08:34 AM
09/20/16 08:34 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
that might work for a manual valve body.
shruggy i would think tranny guys have better ideas. wink
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2157979
09/20/16 10:05 AM
09/20/16 10:05 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Check the rpm it falls back to on the shift.
Doug
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2157990
09/20/16 10:33 AM
09/20/16 10:33 AM
New York
polyspheric Online content
polyspheric  Online Content
New York
Make sure your fluid temperature is up, or the results won't be consistent with actual use.
Boffin Emeritus
Re: How to check for stall (converter) Schooling needed. [Re: dvw] #2157993
09/20/16 10:40 AM
09/20/16 10:40 AM
gregsdart Offline
gregsdart  Offline
Doug
iagree
I found that the tach fooled me when I tried to stall it in high gear, or against the trans brake. I didn't have traction anywhere but on the track, and tach needle momentum sent the needle too high when revving against the transbrake. You won't have accurate info though IMHO unless you have a video , playback tach, or a data logger.
Re: How to check for stall (converter) Schooling needed. [Re: gregsdart] #2157997
09/20/16 10:45 AM
09/20/16 10:45 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Here's a fairly good demo of the 8" converter in my car. Approx 5200? stall but flashes to around 5800-6000 on a pass. I come off the 2 step at 3000. Shift light is set at 7200 and you see I'm shifting with the light not really reacting to it....I still shift by ear and seat of the pants, lol
https://youtu.be/PjXcf95e6v0
WIZE
In Car:
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2158061
09/20/16 12:39 PM
09/20/16 12:39 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Sorry this us kind of off the OP's topic but good info from some known names in the convertor industry. And I thought it was a good read if you guys have a couple minutes take a look in this thread it cleared up some misleading thoughts I had about how convertors work.
http://www.yellowbullet.com/forum/showthread.php?t=1159754
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: How to check for stall (converter) Schooling needed. [Re: dvw] #2158092
09/20/16 01:58 PM
09/20/16 01:58 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Doug
iagree
All that really matters is where it puts your engine speed going down the track. The question is whether there's any home test that's useful. I doubt it, you just can't simulate accelerating the car.
Re: How to check for stall (converter) Schooling needed. [Re: dvw] #2158196
09/20/16 06:17 PM
09/20/16 06:17 PM
montana
BANDIT Offline
BANDIT  Offline
montana
So my delay box has an rpm playback feature that shows the motor at 5600 rpm at launch, but it shows dropping to 6000 rpm after shift. You are saying that the 6000 number is the actual stall speed? jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2158197
09/20/16 06:23 PM
09/20/16 06:23 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Everybody has their own idea of what "stall" is. To me it is the RPM that you see on the tach when you floor it at the starting line.
2011 Drag Pak Challenger
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2158201
09/20/16 06:27 PM
09/20/16 06:27 PM
Kirkland, Washington
Pacnorthcuda Offline
Wow! For decades I understood it to be: From a dead stop apply left foot braking HARD. Then mash the gas, without the car moving (or minimally if the brakes cant hold it) that's your stall.
and yea, its hard on the vert. Fluid builds heat FAST and you risk ballooning the verter if you over do it.
Re: How to check for stall (converter) Schooling needed. [Re: turbo toad] #2158210
09/20/16 06:44 PM
09/20/16 06:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I LOVE reading stuff like this and always save the link so I can re-read it several times to let the info have time to sink in my hard head. LOL Converter stall can make or break a good combo.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2158243
09/20/16 07:37 PM
09/20/16 07:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The "stall" speed is a K factor rating(math).. the "flash"
is what you see at the hit of the pedal(max load/rpm)...
as some said.. its hard to get a true readings.. the drop
back or the high gear or on the trans brake with no chip..
I like the trans brake way.. BUT you have to have the trans
brake.. the drop back method is pretty decent but you dont
see the multiplier in the conv but you still see max rpm
wave
Re: How to check for stall (converter) Schooling needed. [Re: modelmakerinc] #2159237
09/22/16 04:01 AM
09/22/16 04:01 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
My car goes to 6,500 on the trans. brake, on the stands. Racepak shows 6,100 like clockwork coming off the stop in high gear. I never tried getting a Racepak reading on the stands. I did check the Mega 400 and it agreed with the tach. Racepak and Mega 400 have been pretty identical in recent playbacks.
