Re: E-Coat my rims prior to paint or prime and paint?
[Re: Stewpar]
#2157601
09/19/16 06:26 PM
09/19/16 06:26 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
e-coat is a poor excuse for a coating...it's much less than the thickness of paper and the corrosion test results I've seen were "so-so" at best. Topside & Neil have the right idea. Getting down to bare metal is critical & the most rust-prone areas are the seams.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2157988
09/20/16 10:30 AM
09/20/16 10:30 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
The absolute best thing to do, if viable, is to get them dipped in a non evasive stripping then on to e coating. Lightly scuff the e coat and prime with a urethane primer surfacer. Sand. Then paint as you wish. Will be around a lot longer than we will see.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: Stewpar]
#2160201
09/23/16 03:59 PM
09/23/16 03:59 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
There is certainly more than one way to do it.... and OEM's vary. All I can say for sure is from my own personal experience coating OEM wheels. I sold powder coating & competed against e-coat and supplied BMW, Enkei (aftermarket Japanese in the USA & OEM for Honda/Toyota in Japan), Mercedes and Chrysler, all of these in the USA and in Europe.
E-coat is much faster & much cheaper. It does offer "some" corrosion protection, but it is applied at 0.001" thick vs. typical powder coating applied at .015"-.020", so it's much easier to chip from a rock on the road. All OEM's that I'm aware of use an epoxy primer....some use e-coat + epoxy primer and others use just epoxy primer. Epoxies offer the best corrosion protection of any primer. The color coats are typically either urethane or acrylic (they are good with UV-light from the sun while epoxy cannot take the sunlight) and 90% of the clear on top is acrylic, though a few OEM's still use urethane as the clear. Acrylic is more expensive, but is less likely to chip than a urethane.
