727-TransGo TF-2 "Shift Command"? #2156597
09/18/16 01:44 AM
09/18/16 01:44 AM
Chicagoland 'Burbs
SlickRS23 Offline OP
Chicagoland 'Burbs
Has anyone installed a TransGo TF-2 kit without installing the "Shift Command" feature??
This is for a street car that would rarely, if ever see the strip. Might occasionally open the secondaries, but not a full 1/4 mile run.
The trans is a '70 model without the 3-2 part throttle assy.
I don't think I want to shift into 1st gear regardless of car speed. Seems to me this could be damaging to the vehicle if going too fast.
Isn't a downshifting mode already built in from Chrysler??
I'm thinking of leaving the stock 1-2 governor valve in place.
Just wanted to know what peoples thoughts, opinions and ideas on this would be.
Thanks Jeff
Re: 727-TransGo TF-2 "Shift Command"? [Re: SlickRS23] #2156796
09/18/16 01:27 PM
09/18/16 01:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You can do it either way. I usually leave it out for the same reasons you mentioned. beer
Re: 727-TransGo TF-2 "Shift Command"? [Re: SlickRS23] #2156810
09/18/16 01:48 PM
09/18/16 01:48 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
scope
Re: 727-TransGo TF-2 "Shift Command"? [Re: SlickRS23] #2156915
09/18/16 06:21 PM
09/18/16 06:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
IMHO, the Shift Command feature is only useful for off-roaders who might need the engine braking power for really steep descents. In a stocker, there is a limit to what speed you can manually downshift to 1st. (if you pull it into low at 100 mph it will wait to a lower speed before actually downshifting)
Re: 727-TransGo TF-2 "Shift Command"? [Re: SlickRS23] #2156921
09/18/16 06:30 PM
09/18/16 06:30 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I left it out when I did one. A friend of mine did hit 1st on the freeway and spun a bearing. I'll pass on that.
Re: 727-TransGo TF-2 "Shift Command"? [Re: John_Kunkel] #2157370
09/19/16 01:43 PM
09/19/16 01:43 PM
Chicagoland 'Burbs
Chicagoland 'Burbs
This is what I was thinking too, I think I'll leave the stock 1-2 governor valve in the valve body.
Thanks for your replies, Jeff
