Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: 1mean340] #2156152
09/17/16 10:57 AM
09/17/16 10:57 AM
ohio
all spooled up Offline
ohio
nice pass scott
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2156351
09/17/16 05:51 PM
09/17/16 05:51 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Did you ever get the turbo "kit" you were working on figured out??
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2156359
09/17/16 06:19 PM
09/17/16 06:19 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Great job! You're not too far off from needing a chute at this point, with a cast crank!
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2156662
09/18/16 08:10 AM
09/18/16 08:10 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
That's awesome Scott! Jerry sent me a text with the numbers. Man, get the 60' times in line and you will be moving! Congrats!
Randy
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: 1980volare] #2156818
09/18/16 02:07 PM
09/18/16 02:07 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Originally Posted By 1980volare
Congrats. I'm hoping to make it up there for the next No et deal at milan
When is that? Payouts? Got a link??
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: SpareParts] #2156852
09/18/16 03:38 PM
09/18/16 03:38 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Milan tries to run no ET events once a month or so. I don't think it has any payout, you are on your own to set up grudge races.
https://www.facebook.com/MilanDragway/events?key=events
Payso Productions sometimes sets up races throughout the year if you want some smallblock shootout action:
https://www.facebook.com/paysoproductions/?fref=ts
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: Blusmbl] #2158851
09/21/16 04:55 PM
09/21/16 04:55 PM
dogdays Offline
dogdays  Offline
A 360/5.9Mag has a larger main bearing diameter than a 426 Hemi. That's one way to help out the casting, more overlap.
R.
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2159279
09/22/16 10:48 AM
09/22/16 10:48 AM
an8sec70cuda Offline
Awesome for such a mild combo!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: an8sec70cuda] #2159361
09/22/16 01:02 PM
09/22/16 01:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Right in my wheelhouse!
Look stock but carry a big stick and drive it EVERYWHERE.
We need to do Dragweek!
'63 Dodge 330
11.19 @ 121 mph
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2159401
09/22/16 01:34 PM
09/22/16 01:34 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You really have me wanting to do this to the 360 I just pulled out. Its already got ported Edelbrocks it would just need a piston and cam swap.
68 Barracuda Formula S 340
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2159586
09/22/16 06:31 PM
09/22/16 06:31 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Yeah there is no replacement for boost!
Somebody needs to get me a r3 tall deck 59 degree block, and I'll really show you guys what one of these can do! lol
