Exhaust Manifolds-They keep rusting
#215537
02/05/09 11:20 PM
02/05/09 11:20 PM
Posts: 163 Beautiful Downtown Bahama, NC
tact1
Going to blast my iron exhaust manifolds and apply Calyx, which I have never used before. Is there a better coating that will keep them from rusting? Also, I have new tube nuts and want them to look nice. Is there something I can spray them with to keep them from looking bad in 6 months?
"Four out of three people have a problem with fractions"
Re: Exhaust Manifolds-They keep rusting
[Re: tact1]
#215538
02/06/09 12:28 AM
02/06/09 12:28 AM
The rusty look you describe is correct you know. But if you like the cast grey overrestored look,VHT Nu Cast manifold paint works very well.Or you could get them ceramic coated.I have found the POR-15 manifold coating just fall off in no time.
[Re: tact1]
#215539
02/06/09 09:06 AM
02/06/09 09:06 AM
Posts: 2,647 Nashville, TN
MOPARMIKE69
Nashville, TN
I had mine coated by Jet Hot over 8 years ago, They still look brand new. I have tried all other treatments with the same results you are discribing which is re-rust.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#215540
02/18/09 05:59 PM
02/18/09 05:59 PM
Posts: 6,586 SE Pa.
LimeliteAero
SE Pa.
Ive used the Eastwood stainless silver manifold paint on the last three sets of manifolds I painted and NONE have rusted.(the silver is actually light grey) prep work is key. If youre having them blasted make sure the blaster is wearing gloves and be sure to ask him not to handle them without gloves when he is finished. That being said you too will need to keep your bare skin from contacting the bare manifolds. The Eastwood paint gets brushed on.after drying for several weeks you need to heat them to cure them. some have mentioned using an oven to cure them but I have always let the heat from the engine, once they are installed do the work. These manifolds were painted in 03. I know its not the best pic but I dont have any pics with the manifolds the subject. If you want I will be able to get something over the weekend.
[Re: MOPARMIKE69]
#215541
02/18/09 09:24 PM
02/18/09 09:24 PM
Posts: 28,740 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I am going to get mine redone at the one in south Miss. The guy ther was mad as heck since he said that everyone keeps calling him when the hookers rust. He says they never did any for hooker but everyone thinks they did. I saw his work and it was He had a nice gray color as well that looked right at home n stock manifolds. Some here at moparts gave good results on airborne coatings in the Detroit area. But I personaly have not used them
[Re: THESHAKERPROJECT]
#215544
02/19/09 05:05 PM
02/19/09 05:05 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use VHT black header paint.After it cures it starts to turn a grey color,and touch ups are easy.
[Re: Barnabas_Kriss]
#215548
02/20/09 09:57 AM
02/20/09 09:57 AM
MOPARMIKE69
Nashville, TN
Mine were done 10 years ago, about $200 or $250 here is a close up if it is not to big to post
[Re: burdar]
#215549
02/20/09 06:33 PM
02/20/09 06:33 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Wasn't there a post on this just a month ago or something? I think someone said something about soaking the manifolds in gear oil and then baking them. If the manifolds started to discolor, all that was nessesary was to rub some more oil on them.
Yep; that was Scott Smith that posted that IIRC. I wish I had heard that before I used the eastwood cast grey paint......
cheers, Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: ricomondo]
#215552
02/21/09 10:18 AM
02/21/09 10:18 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
As mentioned above, there's a cheaper way to do the job and believe it or not it's pretty darn durable! Take off the manifolds, media blast them clean (clean is important) immediately wipe them down 100% with a HEAVY coating of 90 Weight oil, you want them to be completely saturated with it, should be dripping off. Let them soak for a while, I allow a day or so, then wipe off any excess with a bunch of junk rags. At this point you can do one of two things. Option #1 (best IMO). Use a torch (propane will work) and cook off the oil the best you can. After it's burned off I apply a second coat and repeat, but it's not required, one application usually does it. Option #2. Put them on the car and drive it around until they get good and hot. The drawback to Option #2. is that burning off the oil creates allot of stinky smoke, you may not want that stench in your car, some guys don't mind. Now, after you've done this the results will be a natuaral appearing manifold that is very resistant to rust, you can touch up any spots that appear to be rusting with a daub of oil now and then to maintain them. It works VERY well in my experience and costs basically nothing but some time, plus, your manifolds will look factory "correct".
[Re: LimeliteAero]
#215554
02/21/09 10:33 AM
02/21/09 10:33 AM
Posts: 408 Manhattan, IL
SixPackRT
Manhattan, IL
The last set I had done by Jet Hot was 4/08. The price without shipping was $215.00 (Big Block HP Manifolds). Shipping & handling was $27.00. If you use Jet Hot I would recommend taking the heat control valve out. Maybe someone has experience with that but I was concerned it would not function correctly after the coating was applied. I was very pleased with the results. Scott
70 Coronet RT 440+6 64 Dodge 330 - Future Hemi Clone 17 Challenger Hellcat - Green Go Driver 86 Buick T-Type Turbo V-6
