Indy Valve covers and header evac question
#2152828
09/12/16 12:35 AM
09/12/16 12:35 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I just picked some Indy valve covers and a Moroso header evac kit? For the people that have used that, or something similar, are you using a baffle under the breather? If so, how did you mount them?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Indy Valve covers and header evac question
[Re: cl440]
#2153186
09/12/16 05:57 PM
09/12/16 05:57 PM
dart440_72
Medina, OH
Thanks!!! Do you have any pics of the evac tubes installed to the breathers?
[Re: cl440]
#2153247
09/12/16 07:26 PM
09/12/16 07:26 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I just use these and they seem to be working just fine. Jegs Valve Cover Baffels
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#2153333
09/12/16 10:19 PM
09/12/16 10:19 PM
dart440_72
Medina, OH
Thanks for the pics. Any problem with sucking oil?
[Re: WadeMetzinger]
#2153426
09/13/16 12:06 AM
09/13/16 12:06 AM
Posts: 421 montana
BANDIT
montana
Wade, you have a lot going on in your engine compartment, looks good. I have my breathers at the front of the valve cover with no baffle and haven't had any oil sucking issues. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
