Need some 727 help #2152506
09/11/16 07:16 PM
09/11/16 07:16 PM
baldwinsville new york
a493demon Offline OP
Built a trans for a guy a few months ago.
He just got around to putting it in and has no forward gears.
Seems to want to go in rev. when in 1st gear.
Has a trans brake in it rev. works.
Has all good clutch's (red) in it all alum. servos and billet steel drum.
Please point me in the right direction.
Thanks Brad
Re: Need some 727 help [Re: a493demon] #2152545
09/11/16 08:13 PM
09/11/16 08:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The only component that's applied in all forward gears is the rear clutch. If it goes in reverse both the rear band and high clutch function. I would drop the valve body and air check the rear clutch.
Doug
Re: Need some 727 help [Re: a493demon] #2152598
09/11/16 09:26 PM
09/11/16 09:26 PM
i'll give it a shot .
