4.360 bore w/ 440-1s with 2.25 valves, .760 lift?
#2151158
09/09/16 05:13 PM
09/09/16 05:13 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Does anyone know if you can use 4.360 bore w/ 440-1s with 2.25 valves, .760 lift cam?
I will test it with the block bare and light testing springs but wondered if it has already been checked and not worth me even checking..
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: 4.360 bore w/ 440-1s with 2.25 valves, .760 lift?
[Re: WadeMetzinger]
#2151164
09/09/16 05:22 PM
09/09/16 05:22 PM
Posts: 1,505 TN
SCATPACK 1
TN
Wade My block is 4.375, but I do have plenty of clearance with 2.25 intakes and 1.81 exhaust at 720 lift Jerry
Old Geezer Racing
[Re: WadeMetzinger]
#2151244
09/09/16 07:37 PM
09/09/16 07:37 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
I have ran those heads with the bigger valves like your asking about on several different motors, they cleared okay but I don't remember by how much You know the drill , when in doubt, always check it out I used modeling clay to check the side clearances in the valve pockets and look down the ports with a bore scope to check the cylinder wall to valve clearances, that is not real accurate as far as eye balling it goes IHTHs
