1970 383 Magnum Carb Question
#2150328
09/08/16 01:29 PM
09/08/16 01:29 PM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
What is the correct size carb for a stock 383 Magnum? I know for an automatic car it was a Carter AVS, just not sure what size.
Thanks!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 1970 383 Magnum Carb Question
[Re: Erik]
#2150336
09/08/16 01:41 PM
09/08/16 01:41 PM
Erik
Stroudsburg, PA
Wasn't the Holley on manual cars and the Carter on automatics?
[Re: Erik]
#2150351
09/08/16 01:57 PM
09/08/16 01:57 PM
Erik
Stroudsburg, PA
I'm not worried about date code and such. Car is a '70 Challenger R/T SE N code 383 auto with A/C. Original 383 is gone. 383 in car was rebuilt to stock specs, but the carb needs work. Wanted to know so I can tell if it has the right carb on it or not before I decided to rebuild or replace it.
[Re: EV2RTSE]
#2150401
09/08/16 03:16 PM
09/08/16 03:16 PM
Erik
Stroudsburg, PA
That post was toooooo much! Ugh. Time to build the 440 I have sitting in the back of the garage! LOL The original 383 to the car is long gone and the replacement 383 in it now is orange, has a Holley on it, and log style exhaust manifolds. The car is not 100% correct/original, so I will take certain liberties and do what I want with it.
[Re: Erik]
#2150529
09/08/16 06:53 PM
09/08/16 06:53 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
A "stock-ish" 383 will perform best with a 600-650cfm Holley in my opinion. The 600 vac secondaries are cheap. Don't use a double pumper & a 750cfm is too much. I have run an old Carter Competition Series 500 cfm on a 383 & it ran good, I just think I was missing some top-end.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Erik]
#2150634
09/08/16 09:14 PM
09/08/16 09:14 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Thanks! Anytime you look at a Carter AVS , just turn it over and look at the throttle bores If all four bores are the same size it's a 750 cfm If the primary bores are smaller then the secondary bores it's a 625 cfm Carter AVS 625 cfm was found on the 383 Magnum HP motor if it was coded for a Carter AVS Carter AVS 750 cfm was found on the 440 Magnum HP motor if it was coded for a Carter AVS You might find a Carter AVS 625 cfm on the Non HP 440 motor
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Erik]
#2151252
09/09/16 08:07 PM
09/09/16 08:07 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Holley rates them at 585 cfm
[Re: EV2RTSE]
#2151591
09/10/16 12:23 PM
09/10/16 12:23 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
YIKES! I remember that one. That thread just reinforces how much guys like Randy (Wild RT) and Joe (Beep Beep) are missed on here.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#2151788
09/10/16 07:55 PM
09/10/16 07:55 PM
Posts: 4,165 Florida
cataclysm80
I remember that thread also. I was on here more regularly back then. That thread just reinforces how much guys like Randy (Wild RT) and Joe (Beep Beep) are missed on here.
Beep Beep was always a great source of info. Snoopy also. They are both missed. What happened to Randy? He was always super helpful. You're pretty important around here also!,...and Dan and Barry and Terry and so many others. Moparts is a great forum! Tav
