Question about horn circuit - 70's Dodge truck #2148978
09/06/16 05:40 PM
09/06/16 05:40 PM
Washington State
70Duster440 Offline OP
Washington State
Just wondering if anyone has any insight on this. They used a two wire hookup at the horn with no relay. One side of the horn gets power directly from the fuse panel. The other side of the horn is wired to the horn button/switch for ground - simple enough.
Why is the horn circuit (shared with BU lights) switched and not wired for full time power at the fuse panel? In other words, as it stands, the horn won't function with the key off.
Re: Question about horn circuit - 70's Dodge truck [Re: 70Duster440] #2149005
09/06/16 06:20 PM
09/06/16 06:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why would you want the back up lights powered with the key off? There are fuses that are always powered. Hook the horn to one of them.
Re: Question about horn circuit - 70's Dodge truck [Re: stumpy] #2149017
09/06/16 06:37 PM
09/06/16 06:37 PM
Washington State
Washington State
Of course, I wouldn't want the backup lights to come on when the key is off - but presume that wouldn't occur unless the auto trans was in reverse - which it wouldn't be normally.
I guess I can cut and move wires at the fuse panel. It just seems an odd design, as every other vehicle I have or have owned has a horn that works with the key off.
Re: Question about horn circuit - 70's Dodge truck [Re: 70Duster440] #2149182
09/06/16 10:06 PM
09/06/16 10:06 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Normal for the trucks of the era.
Angry white pureblood male
Re: Question about horn circuit - 70's Dodge truck [Re: 70Duster440] #2149197
09/06/16 10:27 PM
09/06/16 10:27 PM
Washington State
Washington State
Thanks.
