Replacement upper control arms.. #2148753
09/06/16 01:16 PM
09/06/16 01:16 PM
Missouri
MOBodyman Offline OP
Missouri
I have a '69 Coronet 500 with drum brakes. I'm needing some upper control arms. Hard to find clean undamaged ones around here so I'm thinking about these. The description states 'for larger ball joint only'. My question is, does my car with drum brakes have the 'larger' ball joint?
http://www.ebay.com/itm/Upper-Control-Arm-Kit-W-cam-Bolts-6-Pcs-1970-1974-Dodge-Challenger-UDCA60-61RL-/201585862056?fits=Year%3A1969%7CMake%3ADodge%7CModel%3ACoronet&hash=item2eef7425a8:g:f4sAAOSwa-dWj~Jx&vxp=mtr
TIA,
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Replacement upper control arms.. [Re: MOBodyman] #2148967
09/06/16 05:33 PM
09/06/16 05:33 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes. Large ball joint -LBJ
Re: Replacement upper control arms.. [Re: autoxcuda] #2149026
09/06/16 06:58 PM
09/06/16 06:58 PM
Missouri
Missouri
Thanks for the reply. I 'thought' it did but then doubted myself because the car has drums on the front.
Dallas
Re: Replacement upper control arms.. [Re: MOBodyman] #2149180
09/06/16 10:05 PM
09/06/16 10:05 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
A bodies with 9" drums had small ball joints. B bodies all had the next size larger, a bodies with bigger brakes had the same size.
C bodies and trucks were bigger yet.
Angry white pureblood male
Re: Replacement upper control arms.. [Re: ruderunner] #2149383
09/07/16 03:11 AM
09/07/16 03:11 AM
Missouri
Missouri
Thanks for clarifying.
Dallas
Re: Replacement upper control arms.. [Re: autoxcuda] #2150240
09/08/16 10:50 AM
09/08/16 10:50 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I would be suspect of the bushings and joints those arms come with. Moog ball joints cost half as much as what they're asking for the entire thing.
Re: Replacement upper control arms.. [Re: MarkZ] #2150642
09/08/16 09:25 PM
09/08/16 09:25 PM
IN
ahy Offline
ahy  Offline
IN
There a lots of choices for UCA's these days which is nice to see. Re-pop stamped arms and many flavors of tubular arms.
If you want a clean used set from a '70 E California car send a PM. Ball joints and bushings are removed. I replaced them with FF tubular pieces. For a good home I would not need much more than shipping.
Re: Replacement upper control arms.. [Re: MarkZ] #2150827
09/09/16 01:55 AM
09/09/16 01:55 AM
Missouri
Missouri
I'm sure they aren't the highest quality. Hopefully they are better than the 45+ year old parts on it now.
I had already purchased Moog ball joints and poly bushings. Then the mechanic tears it down and found the arms are shot.
I guess I could put the good parts in the new arms.
Dallas
Re: Replacement upper control arms.. [Re: ahy] #2150834
09/09/16 02:04 AM
09/09/16 02:04 AM
Missouri
Missouri
I wish I had known you had those as I had already purchased Moog ball joints and poly bushings. However I ordered the new arms a day or 2 ago and they have already shipped. If I don't like them for some reason I'll check back with you.
Thanks for the offer,
Dallas
