Recommendation Needed for Big Block High Flow Water Pump.
#2148795
09/06/16 02:03 PM
09/06/16 02:03 PM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Anyone have a particular pump that really gave them additional flow. I've seen a few advertised and tried in past applications but didn't seem to see much in extra flow compared to a standard pump.
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Recommendation Needed for Big Block High Flow Water Pump.
[Re: TimS]
#2148810
09/06/16 02:30 PM
09/06/16 02:30 PM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
There have been a couple of threads on this subject in the last week or two and dozens over the years. Shouldn't be hard to find. Go to the top of the page and type 'best water pump' (leave out the ') in the little box that says Google custom search. Then click search button. Ignore the Google ads and go straight down to the smaller print moparts links. Good luck finding much of a concensus. Most will say milodon or flowcooler but many will say it doesn't make much differnce. Make sure you have the correct size pulleys for the pump you choose.
[Re: TimS]
#2148896
09/06/16 03:51 PM
09/06/16 03:51 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Any of the pumps w/ the anticavitation plate on the impeller work god. I've used both the Milodon and FlowKooler pumps w/ good results.
Plugging the bypass hole under the thermostat in the factory housings helps drop the temp also. Tap the hole for 3/8" NPT (no need to drill it), install a plug w/ a 1/8" hole drilled through it so it will bleed the air out.
[Re: TimS]
#2148902
09/06/16 03:59 PM
09/06/16 03:59 PM
TimS
Walton, Indiana
Thanks. I found the thread from last week. Lots of good feedback on this subject.
[Re: TimS]
#2148989
09/06/16 05:53 PM
09/06/16 05:53 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
I run an MP housing thats 30 40 years old and MP pump.Been on at least 15 years and still going good.Keeps my 440 under 190 all day.Rocky
Chrysler Firepower
[Re: an8sec70cuda]
#2149466
09/07/16 11:17 AM
09/07/16 11:17 AM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Plugging the bypass hole under the thermostat in the factory housings helps drop the temp also. Tap the hole for 3/8" NPT (no need to drill it), install a plug w/ a 1/8" hole drilled through it so it will bleed the air out. In the instrumented test I referenced on last week's post the housings with the open hole greatly outflowed the housing without the hole.
[Re: feets]
#2157321
09/19/16 12:32 PM
09/19/16 12:32 PM
an8sec70cuda
Plugging the bypass hole under the thermostat in the factory housings helps drop the temp also. Tap the hole for 3/8" NPT (no need to drill it), install a plug w/ a 1/8" hole drilled through it so it will bleed the air out. In the instrumented test I referenced on last week's post the housings with the open hole greatly outflowed the housing without the hole. Don't care what the flow test says. I can tell you that I, and everyone else I know that has done this modification, have seen around a 10° drop in temp b/c of blocking that hole.
