Re: Engine Rebuild ~6mo before starting - Assy Lube? Grease?
[Re: GoodysGotaCuda]
#2148393
09/05/16 11:06 PM
09/05/16 11:06 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I am currently sitting on a 440 shortblock that was assembled a few months ago. I used a paint brush to paint on ATF on everything, and then wrapped it tightly in a garbage bag on the engine strand. I have opened it up and checked it a few times and it is fine.
I used ATF because I have seen engine builders use ATF to wipe parts down during the engine assembly process. I figured it would keep things from rusting - and when i wipe it all off, things will be clean before i button it up.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: OzHemi]
#2148450
09/06/16 12:38 AM
09/06/16 12:38 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I wouldn't worry too much about the mains and rods, since I'm sure you used some kind of lubricant when you built the short block. Just prime the engine with a drill before you turn the crank and the bearings should have plenty of oil Dumb question, but can you even prime a new gen Hemi with a drill ? Not a dumb question... I have no idea! Missed the "5.7" part. I've been playing mostly with B/RB engines for a long time.
[Re: Cab_Burge]
#2148458
09/06/16 12:45 AM
09/06/16 12:45 AM
RapidRobert
eng oil only on the rings/cyl walls. you need friction there for proper breakin. obviously you dont want em dry but nothing slicker than eng oil. thick paste of some sort reasonably lightly on bearings & dont forget the sides of the thrust bearing halves and on pushrod tips & valve stem tips & good squirt of oil on valve stems. oil on lifter sides. cam lube on lifter bottoms/lobes. anything that moves. definitely preoil
#2148502
09/06/16 01:30 AM
09/06/16 01:30 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I have rebuilt several "modern" engines that you cant prime through the distributor hole. I built a priming tool out of clear 1 1/2 inch pool filter hose about 20" long with Pvc Caps on each end. On one end I threaded in a valve and air chuck on the other I threaded in an adapter that connected to a 1/4 clear line. I attached the line to another adapter that threaded into the oil pressure sending unit. Fill it with oil, attach air line keep the pressure low and open the valve slow and you will send oil through the motor, repeat 2-3 times and you are good to go. BE CAREFUL IF YOU USEE FULL COMPRESSOR PRESSURE, or don't open slowly IT WILL BLOW UP IN YOU FACE. I dont have pice but can take some and email them. Scott
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: OzHemi]
#2148635
09/06/16 09:36 AM
09/06/16 09:36 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I wouldn't worry too much about the mains and rods, since I'm sure you used some kind of lubricant when you built the short block. Just prime the engine with a drill before you turn the crank and the bearings should have plenty of oil Dumb question, but can you even prime a new gen Hemi with a drill ? No, oil pump is crank driven. There are some alternative ways to force feed it, however.
[Re: larry4406]
#2149907
09/07/16 09:00 PM
09/07/16 09:00 PM
RapidRobert
I've used that tube of lubriplate. knead/squeeze the tube in your fingers to mix the white grease with the brown goo on the inside
[Re: RapidRobert]
#2149915
09/07/16 09:12 PM
09/07/16 09:12 PM
Posts: 521 Virginia
larry4406
Virginia
I've used that tube of lubriplate. knead/squeeze the tube in your fingers to mix the white grease with the brown goo on the inside Agreed....
