How much are my small headers killing my performance
#2148281
09/05/16 09:16 PM
09/05/16 09:16 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
I have a 900 horsepower W7 small block with 1 7/8 headers on it. I put more gear in the rear end. (4.88 to 5.38) and more converter doesn't seem to make much difference on the performance. I'm thinking the headers are holding this thing back big time..runs 9.20s in 3000 da air @ 2800 lbs ???????????
Re: How much are my small headers killing my performance
[Re: Plymouth340]
#2148297
09/05/16 09:26 PM
09/05/16 09:26 PM
hustlin hoosier
We have tried about everything possible with headers and never found over a few hundredths going from what we thought was a great set of headers to what we thought was the worst set of headers. I hope you have better luck chasing et with we exhaust than we did.
[Re: camastomcat]
#2148346
09/05/16 10:21 PM
09/05/16 10:21 PM
Plymouth340
CEDAR RAPIDS
that's just it. I think they are considering the step headers that were on it when the previous owner was running it.. Converter is 7000 stall and motor makes peak hp at 9000
[Re: Plymouth340]
#2148764
09/06/16 01:27 PM
09/06/16 01:27 PM
Posts: 4,210 New York
polyspheric
New York
Tried shortening the collector?
Boffin Emeritus
[Re: Plymouth340]
#2148813
09/06/16 02:32 PM
09/06/16 02:32 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It's "900hp", what headers were on it when it made 900hp?
2800 lbs, 148mph shows 700hp on the moroso chart. Figuring 10% loss for air quality, parasitic losses, etc, you're still off over 100hp. I don't know if the headers would be worth that kind of power.
[Re: Plymouth340]
#2148916
09/06/16 04:25 PM
09/06/16 04:25 PM
fast68plymouth
So. Burlington, Vt.
At seasons end...... Might be worth a trip to the dyno and see just how much difference in power there is between the headers......before going through the effort of fitting them to the car.
[Re: camastomcat]
#2149020
09/06/16 06:44 PM
09/06/16 06:44 PM
fast68plymouth
So. Burlington, Vt.
Isn't Dwayne Porter a small block guy? Mmmmmmmm, not particularly. Never even laid my eyes on a W7 head in person.
[Re: Plymouth340]
#2149023
09/06/16 06:48 PM
09/06/16 06:48 PM
fast68plymouth
So. Burlington, Vt.
I need to talk to someone about it that knows more than me that's why I'm asking. Unless someone has tested a motor combo that's very close to yours with both sizes of headers you're talking about, and they're willing to share that info, you might have to test if for yourself to find out exactly what the answer is....... On your motor. 100+ hp seems like a stretch for a header swap to me....... But that's what the dyno is for. To provide answers to those questions.
