Wix filter part # needed
#2148098
09/05/16 04:49 PM
09/05/16 04:49 PM
RapidRobert
std 3/4-16 thread. longest length/no bypass. thank you for your time
Re: Wix filter part # needed
[Re: RapidRobert]
#2148119
09/05/16 05:03 PM
09/05/16 05:03 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
51773, dont know about bypass or not.
Mopar to the bone!!!
[Re: RapidRobert]
#2148127
09/05/16 05:13 PM
09/05/16 05:13 PM
72Swinger
Nebraska
51512 has no bypass, but is smaller OD which may or may not work.
[Re: Dodgem]
#2148144
09/05/16 05:41 PM
09/05/16 05:41 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
51515R
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Dodgem]
#2148149
09/05/16 05:47 PM
09/05/16 05:47 PM
RapidRobert
that'll work. thanks guys, I'm on it!
[Re: @#$%&*!]
#2148263
09/05/16 08:53 PM
09/05/16 08:53 PM
RapidRobert
Yes & even better cuz this is for my circle track 360 with external mounted dual parallel filters (space ain't an issue) and an accumulator & with the 4 qt OE pan sump (the real prob here) I need ALL the capacity I can muster tho that might not technically help keep the pickup covered from the extra (it is baffled tho which helps a bit in that regard)
[Re: 72Swinger]
#2149176
09/06/16 10:01 PM
09/06/16 10:01 PM
RapidRobert
Well I'll be damned! I never woulda thought about swapping nipples to a large one. Sometimes it ain't what you know, it's WHO you know, thank you!
[Re: 72Swinger]
#2149359
09/07/16 02:00 AM
09/07/16 02:00 AM
RapidRobert
I will look at the MFR of the dual remote filter & call them. I missed the 4 holes & that is as pathetic as the minimal holes in the OE round blockoff plate
