Fel-Pro Gasket Set for 340 / 416 #2147781
09/05/16 02:42 AM
09/05/16 02:42 AM
Melbourne, Australia
limelighte55 Offline OP
Can't seem to find a full Fel-Pro gasket set for my 416 which has the 1008 head gaskets. I need a full gasket set with 0.039' thick head gaskets (PN: 1008). Anyone know of a part number for a complete gasket set?
Chris.
Re: Fel-Pro Gasket Set for 340 / 416 [Re: limelighte55] #2147834
09/05/16 09:24 AM
09/05/16 09:24 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I will say that I have never looked but I doubt they make one that comes with the 1008s, you will likely have to buy a kit then a pair of 1008s.
Have you checked to see what gaskets you really need from the kit? Last time I bought a kit it went mostly unused. I think I only used the oil pan and timing cover gaskets, the rest was different due to aluminum intake, thick cover gaskets, etc. Next time I have one apart it will be all Superformance stuff.
68 Barracuda Formula S 340
Re: Fel-Pro Gasket Set for 340 / 416 [Re: limelighte55] #2147845
09/05/16 10:26 AM
09/05/16 10:26 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've never seen a "set" with 1008 head gaskets. As Bad340fish said just buy head gaskets and the other gaskets you need. I used Superformance gaskets on everything but the intake and valve covers. My heads are Indys and I needed .040" so I had Cometic make them and I already had valve cover gaskets.
http://www.manciniracing.com/smblga.html
