Re: How much centrifugal advance in a small block distributor?
[Re: pyp1000]
#2147596
09/04/16 10:11 PM
09/04/16 10:11 PM
RapidRobert
MSD dist or MP (mallory or old style) dist?. 2 commmon SB slots are stamped 11 & 17 (22/34 on crank) on older electronic dists. not normal at all for the box to change the timing. it might "take out" (improperly delay) timing at higher RPMs a common complaint of the new (er) orange boxes but not at idle. is your idle speed changed which it would some if the initial was changed 4 deg. I'd open up the dist & see what you see for starters. what box did you have & what did you swap in?
[Re: pyp1000]
#2147629
09/04/16 10:54 PM
09/04/16 10:54 PM
RapidRobert
Actually mixing and matching ain't the end of the world. lets see what's up with the dist (including the can). Holler when you find out anything
[Re: pyp1000]
#2147806
09/05/16 04:34 AM
09/05/16 04:34 AM
Posts: 3,884 Oregon
hooziewhatsit
adjusting the vacuum part of the can with an allen wrench will only change at what vacuum point the advance will start moving.
To limit the degrees it provides, you need to open the distributor and block part of the travel.
pvp, I wonder if distributor has a heavy spring with a slot in it. That keeps some timing out until waaay high in the RPMs, thus making it look like you only have 11 total mechanical. Usually best to replace it with a light spring from the Mr Gasket set to get the total timing in at a lower RPM.
[Re: pyp1000]
#2147971
09/05/16 01:36 PM
09/05/16 01:36 PM
Posts: 857 charlotte,nc
pyp1000
charlotte,nc
I am pretty sure the vacuum can is toast. I hooked it up to the mi-t-vac and couldn't pull a vacuum at all. I tested the mi-t-vac on another component and it was working fine. Just in case, I borrowed a friends mitivac and had the same results. Fortunately my dad has a collection of vacuum cans that he has collected throughout the years and he has tested each of them. So I am pretty sure I can get that fixed. I ran the rpm up to 3000 rpm without seeing any more advance. If it's got a super heavy spring to keep it from advancing past that, then I definitely need to pull the distributor and look into it. I wish I knew someone with a sun distributor machine. This would be so much easier Thanks for all of your replies. I will keep you posted. kev
[Re: pyp1000]
#2148017
09/05/16 02:49 PM
09/05/16 02:49 PM
RapidRobert
first we gotta fix the popping/rough idle (the can may be leaking-vac leak & there are other possibilities) & we can dial in the dist spot on WO a dist machine. you might plug the line to the can & take it back out & see if it straightens out. one thing at a time. EDIT with a bit of thought the can is almost certainly leaking which is causing the vac leak. I've never seen a can hang up to where it will not advance, it'd have to be something that got loose/hung up in the dist, not likely. holler when you can
[Re: pyp1000]
#2148711
09/06/16 12:25 PM
09/06/16 12:25 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
If it's a stock replacement distributor it's going to have close to 30 degrees of mechanical advance , even wit ha heavy spring the weights will keep pulling it. you need to go higher than 3k rpm to see the full advance ... and get rid of those mopar electornic ign units , crappy old technology.
