smash transmission lines #2146468
09/02/16 11:03 PM
09/02/16 11:03 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
I have 727 transmission with no reverse.i can see one the transmission lines are smashed.would that cuz it not to go in reverse?
Re: smash transmission lines [Re: mopar muscle7271] #2146480
09/02/16 11:21 PM
09/02/16 11:21 PM
I'm thinking no
Re: smash transmission lines [Re: mopar muscle7271] #2146484
09/02/16 11:30 PM
09/02/16 11:30 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Doubt it. wonder if your shift lever/linkage may have been damaged and knocked out of adjustment when the line got bent. Crawl under there with the vehicle on jack stands and try manually switching gears.
Re: smash transmission lines [Re: mopar muscle7271] #2146586
09/03/16 01:57 AM
09/03/16 01:57 AM
las vegas,nv
las vegas,nv
I did adjust the linkage,still no reverse.reverse work when i put the trans in the car.
Re: smash transmission lines [Re: mopar muscle7271] #2146815
09/03/16 03:06 PM
09/03/16 03:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Cooler lines have nothing to do with shifting into any gear.
If the Reverse failure was sudden, pull the pan and observe the band lever; if it's sagging or you can pull down on it with little/no resistance, look for a broken band, broken band linkage or band link popped out.
Re: smash transmission lines [Re: mopar muscle7271] #2146888
09/03/16 06:00 PM
09/03/16 06:00 PM
las vegas,nv
las vegas,nv
If the trans fliter is clogged,could that be part of it?
Re: smash transmission lines [Re: mopar muscle7271] #2146896
09/03/16 06:17 PM
09/03/16 06:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
one might want to listen to Mr. Kunkel as he is considered to be one of the sites authorities on torqueflites whistling beer
