DROP IN ROLLER LIFTER SB #214541
02/05/09 03:03 AM
02/05/09 03:03 AM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
I need some opions on best drop in solid roller lifter sb.No bushing of block and min. clearencing
Re: DROP IN ROLLER LIFTER SB [Re: 71Pan] #214542
02/05/09 06:44 AM
02/05/09 06:44 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
why not factory rollers?
late model trucks with the 5.2s and 5.9s had roller lifters stock.
**Photobucket sucks**
Re: DROP IN ROLLER LIFTER SB [Re: 71Pan] #214543
02/05/09 06:45 AM
02/05/09 06:45 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I need some opions on best drop in SOLID roller lifter sb.No bushing of block and min. clearencing
oops! nevermind. I missed that part!
Re: DROP IN ROLLER LIFTER SB [Re: 70Cuda383] #214544
02/05/09 09:13 AM
02/05/09 09:13 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
stock roller lifters won't work in older blocks.
contact board member OU812. he has some nice ones from comp cams that aren't in their catalog yet.
2017 Grand Cherokee Overland
Re: DROP IN ROLLER LIFTER SB [Re: patrick] #214545
02/05/09 10:39 AM
02/05/09 10:39 AM
MARYLAND
69Cuda340S Online content
69Cuda340S  Online Content
MARYLAND
I believe the ones Brian (ou812) sells are retrofit solid roller lifters? His are nice because the link bar is toward the center of the engine so no grinding on the block needed.
Re: DROP IN ROLLER LIFTER SB [Re: 70Cuda383] #214546
02/05/09 10:40 AM
02/05/09 10:40 AM
ccarson Offline
ccarson  Offline
Contact Best Machine they can hook you up with the correct part from Comp, and yes they are not in the the comp catalog yet
Re: DROP IN ROLLER LIFTER SB [Re: 71Pan] #214547
02/05/09 10:40 AM
02/05/09 10:40 AM
Brunswick Ohio
dusta340 Offline
dusta340  Offline
Brunswick Ohio
you will have to grind on the lock a little. but i used a comp solid body roller lifter no bushing no bs i ran it for 2 years no problems. if you want i can get you part numbers for the lifters i used
Re: DROP IN ROLLER LIFTER SB [Re: dusta340] #214548
02/05/09 10:54 AM
02/05/09 10:54 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
The lifters he's referring to, have the link bar to the
inside.......away from the block.I doubt if they require
clearancing at all. Uncovering the oil galley, is a whole
different problem. Running smaller lift lobes with higher
rockers would remedy this but, high ratio rocker arms for
SB Mopars is big $$$$. The last 2 blocks I had bushed
cost me $511.00 apiece.
Re: DROP IN ROLLER LIFTER SB [Re: S/ST 3040] #214549
02/05/09 11:01 AM
02/05/09 11:01 AM
Brunswick Ohio
dusta340 Offline
dusta340  Offline
Brunswick Ohio
the tie bar goes torwards the head and you do have to grind. if you put the tie bar on torwards the inside of the block it will hit the push rod. i ran .673 lift cam with a 1.6 rocker no problems no need to bush the block. unless you go nuts with the lift it should not uncover the oil passage.
Re: DROP IN ROLLER LIFTER SB [Re: dusta340] #214550
02/05/09 11:08 AM
02/05/09 11:08 AM
Brunswick Ohio
dusta340 Offline
dusta340  Offline
Brunswick Ohio
pics of the lifters i used
Re: DROP IN ROLLER LIFTER SB [Re: dusta340] #214551
02/05/09 11:09 AM
02/05/09 11:09 AM
S/ST 3040 Offline
S/ST 3040  Offline
The amount of lobe lift you can run depends on where the oil
galley intersects the lifter bores, base circle of the cam and
style of lifter.
Galley to lifter bore varies greatly, block to block so xxx lobe
lift with xxx lifter is not going to consistantly work on every
block. Like most fun things about building engines.......you
have to check first.
Re: DROP IN ROLLER LIFTER SB [Re: dusta340] #214552
02/05/09 11:11 AM
02/05/09 11:11 AM
Brunswick Ohio
dusta340 Offline
dusta340  Offline
Brunswick Ohio
they are a 828-16 comp part number
Re: DROP IN ROLLER LIFTER SB [Re: dusta340] #214553
02/05/09 12:13 PM
02/05/09 12:13 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Will Comp use the same part number and just change design or will the new lifters be a different P/N??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: DROP IN ROLLER LIFTER SB [Re: CJK440] #214554
02/05/09 12:48 PM
02/05/09 12:48 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The 828-16s are the old number. I dont think they superceded. Check with Brian, he actually helped them deveolp them as I understand it. In any event, I don't run a solid roller lifter without bushings. Ever.
Re: DROP IN ROLLER LIFTER SB [Re: dusta340] #214555
02/05/09 12:55 PM
02/05/09 12:55 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
My 828-16s opened the oil passage with my cam which is .430 cam lift. It wasn't just barely either it opened them up alot. Block is getting tubed at the machine shop right now.
I love putting motors together then taking them back apart .
68 Barracuda Formula S 340
Re: DROP IN ROLLER LIFTER SB [Re: moper] #214556
02/05/09 12:56 PM
02/05/09 12:56 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
And about the gains of using a roller cam ?
Could you guess something ?
Re: DROP IN ROLLER LIFTER SB [Re: 71Pan] #214557
02/05/09 03:57 PM
02/05/09 03:57 PM
ohio
prochamp Offline
prochamp  Offline
ohio
doug herbert sells drop in rollers for about half the cost of the comps.part#hertev.
Re: DROP IN ROLLER LIFTER SB [Re: prochamp] #214558
02/05/09 06:08 PM
02/05/09 06:08 PM
South Carolina
a408swinger Offline
mopar addict
a408swinger  Offline
mopar addict
South Carolina
Those are what I run as well. $219.00 a set and no grinding and no bushing or tubing. Just drop them in with the link bar toward the sides of the of the lifter valley (backwards) and thats it. Ive been running mine on the street and at the track on a car that runs 10.30's on motor and 9.20's on spray with no issues. Good products.
Re: DROP IN ROLLER LIFTER SB [Re: a408swinger] #214559
02/06/09 01:05 AM
02/06/09 01:05 AM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
Buying herberts Thanx
Re: DROP IN ROLLER LIFTER SB [Re: a408swinger] #214560
02/06/09 02:14 AM
02/06/09 02:14 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I think they recently jumped to about 265 at Doug Herbert, IIRC.
I think Chet Herbert still has them listed at $218.
